Spacers, what are they??
Discussion in 'Wheels & Tires' started by Rconectn, Dec 18, 2010.
  1. Dec 18, 2010 at 7:11 PM
    Rconectn
    Rconectn [OP] Well-Known Member
    Miami, FL
    '10 Regular Cab
    Sorry for the n00b question, but what are they and how do you know if you need to use them?
    I would like to put some Cragar 345 Series Silver "D" Window 16x8, offset 13mm, Rearspacer 5 on my 5lug. I plan on doing a Readylift 2.75"F/1.75"R what I would like to know is will I have any problems like having to replace the wheel studs or putting spacers? If I do I just might have to go for some other rims.
  2. Dec 18, 2010 at 7:16 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    http://www.roughcountry.com/images_large/jeep_1090.jpg
    These are wheel spacers. You bolt them on as you would your wheels and then bolt your wheels on to them. They space your wheels out widening your stance and give you more clearance between say tires and upper control arms.
  3. Dec 18, 2010 at 7:56 PM
    Rconectn
    Miami, FL
    '10 Regular Cab
    Is it a necessity when putting after market rims?
  4. Dec 18, 2010 at 8:00 PM
    Pugga
    Massachusetts
    Not all rims. If you don't have the proper backspacing you are required to use spacers to clear the brake calipers or if you run fat tires so they don't rub the upper control arm (they might still rub other pieces of the body though depending on the tire size). I don't know much about what backspacing requires spacers, there are others who know a lot about this issue. There have been a lot of threads about this so worst case if you search backspacing I'm sure you'll get a lot of hits.
