Spacers with factory TRD suspension?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09sportowner, Dec 3, 2009.
  1. Dec 3, 2009 at 6:17 AM
    09sportowner
    09sportowner [OP] Well-Known Member
    Texas
    09 Sport
    I was thinking about getting spacers to allow for bigger, wider tires. I don't think i want to get into the whole lift thing due to cost and inherent problems, but spacers seem to be the fit. Does anyone have any opinions or pics with factory suspension and spacers?
    Thanks!!
  2. Dec 3, 2009 at 6:18 AM
    taco man31
    taco man31 Well-Known Member
    i was about to ask the same quesion
  3. Dec 3, 2009 at 6:19 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I gots some for inside the coils or the ones that go on top in between strut assembly and frame......cheap.:DPM for pics
  4. Dec 3, 2009 at 6:20 AM
    GTVAPSAMTIK
    GTVAPSAMTIK Well-Known Member
    SOHAIL
    Fort Carson, CO
    2010 TRD OFF-ROAD 4X4 Automatic
    EXTANG Tuff WeatherTech Liners Toyota Bed Mat Coverkind Seat Covers
    I want to install spacers but do they have any side effects I should be aware of before I buy em?
  5. Dec 3, 2009 at 6:24 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Subscribed
  6. Dec 3, 2009 at 7:52 AM
    Meeocky
    Meeocky GEAUX TIGERS!
    Louisiana
    Black '05 Tacoma
    In for answers...
  7. Dec 3, 2009 at 8:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When you say *Spacers* - what are you referring to?
    Lift spacers -or- wheel spacers?
    Lift spacers are a suspension lift. Wheel spacers go inbetween the wheel & your rotor/mounting surface.
  8. Dec 3, 2009 at 8:04 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    A spacer IS a lift...unless you mean wheel spacers... they are a cheap way to lift your truck. I used toytec spacers for over a year and they are good for a beginer lift. They will however give you a rougher ride.
  9. Dec 3, 2009 at 8:06 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    here is a pic of my truck with stock shocks and the toytec 3" spacer lift with AAL
  10. Dec 3, 2009 at 8:07 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Yeah at about 100,000 miles you'll be replacing your CV boots. You'll also be in for a very uncomfortable ride! You're better off going with the billies.
    My gf's uncle has a 2" spacer lift on his F150, and he's at 112,000 miles on his truck and the last time I talked to him, he was ordering new CV boots.
  11. Dec 3, 2009 at 8:11 AM
    KaoskrewPB
    KaoskrewPB -Empty-
    Here's mine with the RevTek 3" spacer lift
  12. Dec 3, 2009 at 8:18 AM
    09sportowner
    Texas
    09 Sport
    Sorry for the confustion, but i was referring to wheel spacers that will allow for bigger, wider tire. Please correct me If I'm way off here, but I don't want to do the lift as I don't offroad and don't want the issues that others have but I would like a bigger tire to give it a meaner look.
    Thanks!!
  13. Dec 3, 2009 at 8:24 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Just go with beefy 265's than. You will most likely rub with anything else if you go bigger.
  14. Dec 3, 2009 at 9:16 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    ^^X2
    I have a 2.5" lift and have 285 tires, I added 1.25" wheel spacers and it made them rub way worse
  15. Dec 3, 2009 at 9:28 AM
    09sportowner
    Texas
    09 Sport
    Those will look noticably different and no spacers needed?
    Thanks!
