spanner wrench
Discussion in 'Suspension' started by Mexicutioner, Apr 29, 2011.
  1. Apr 29, 2011 at 7:42 PM
    Mexicutioner
    Mexicutioner [OP] Well-Known Member
    Joel
    Chula Vista, CA
    '10 4x4 TRD DCSB Off Road
    FRONT: Total Chaos 3.5 4x4 kit, Fox 2.5 x 8" coilovers REAR: Defined Engineering SUA kit, Fox 2.5 x 14" smooth bodies, Fox 2.0 x 4.0" bumps, American Motorsports bolt in bedcage MISC Mcneil Racing Inc Glass all around, Afe stage II cai, weathertech floormats, flowmaster 40, rigid led 30" combo, rigid dually reverse cargo lights, Bamf sliders, 1.25" spidertrax, 20% tint - front, 50% tint - rears AUDIO Alpine w910 headunit, Alpine 6.5" type r components in front, Alpine 6.5" type r coaxials in rear, 2 Alpine 10" type r shallow mount subs w/ custom box, JL Audio 900w 5 channel HD amp, steering controls & reverse camera integrated, Stinger Roadkill matted on entire interior
    has anyone experienced using generic laser cut spanner wrenches??? im trying to use em for my 2.5 fox coilovers and dnt seem to be working. just in case i might have to buy some better ones. thanks
  2. Apr 29, 2011 at 7:43 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I think Chris4x4 made some , I'm not sure what he did with them , perhaps he will chime in .
  3. Apr 29, 2011 at 7:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I didnt "make" them, but re made existing ones......wich ColtsTRD threw away before I could test them...Anyway, a drill bit with a 3/8" shaft will work. A 25/64" is the actual size of the hole, IIRC.
  4. Apr 29, 2011 at 8:08 PM
    Mexicutioner
    Joel
    Chula Vista, CA
    yeah i tried using em and no go so i might have to order me a new set. do they have to be fox's for it to work or as long as its for a 2.5 sized coilover??
  5. Apr 29, 2011 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm......I think the ones for King and Icon fit.
  6. Apr 29, 2011 at 8:13 PM
    OZ-T
    Peter North
    British Columbia
    Sorry for trying to help .
  7. Apr 29, 2011 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It was a valiant attempt.
  8. Apr 29, 2011 at 8:16 PM
    Mexicutioner
    Joel
    Chula Vista, CA
    im liking the icon one from DSM, its got the 2 pins makes it nice and easy but dnt u need a small one and a larger one?? or can u just use the same one?? not sure....
  9. Apr 29, 2011 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The holes are the same size. I prefer the straight adjuster bars, as they wont spin around under pressure, and you can apply alot of leverage.
  10. Apr 29, 2011 at 8:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. Apr 29, 2011 at 8:25 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I still don't get why people don't just use 9mm hex wrenches...like I do...all the time...
  12. Apr 29, 2011 at 8:28 PM
    Mexicutioner
    Joel
    Chula Vista, CA
    im assuming they work just as well
  13. Apr 29, 2011 at 8:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont like how they distort the hole. In the past, they have gotten distorted enough that the wrench slips out. Plus, The pin type adjuster is longer, allowing for more leverage. And a 9mm wrench is a little on the small side. THe actual hole diameter is 9.52mm....IIRC.
  14. Apr 29, 2011 at 8:40 PM
    jandrews
    I have never had a problem with any of the items you note. But then, all my experience is on Icons. I can't speak for other brands.
  15. Apr 29, 2011 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Seems many folks have used the 9mm alen wrench method with good results. Im probably more ham fisted than others too...
  16. Oct 25, 2011 at 4:45 PM
    rwalker
    rwalker Well-Known Member
    Rian
    Portland
    Tacoma Baja TX
    Have either of you guys tried the 9MM hex wrench on the toytec coilovers?
