Spare Bed Mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blu4.0, Feb 13, 2019.
  1. Feb 13, 2019 at 5:32 PM
    Blu4.0
    Blu4.0 [OP] Let's Go Blues!
    Jared
    Manhatten, KS / STL
    2014 DCSB TRD Sport
    Ultragauge, topper, remote start, flow master muffler, scs ray 10s, meso gasshole, meso dome, hyper retrofits, kc amber fogs, empyre grill, cboy custom bedsides and emblems, arb awning + annex, Trd baja suspension lift kit, and icon rxt leaf packs
    Does anybody know of a company or perhaps a TW member that makes a bracket of some sort to hold a spare in the bed. Whether it goes in the bed rail or whatnot. Looking to upgrade all 5 wheels and dont think a bigger tire will fit under the bed.
  2. Feb 13, 2019 at 5:47 PM
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
    Avid makes a tire carrier that is secured by the bed rails.
  3. Feb 13, 2019 at 5:55 PM
    toycoma 2016
    toycoma 2016 Well-Known Member
    jason
    Williamsport, TN
    2021 cement OR 4x4 dcsb
    Lots
    Amazon, search for RHTC-35L.
  4. Feb 13, 2019 at 5:55 PM
    Blu4.0
    Jared
    Manhatten, KS / STL
    2014 DCSB TRD Sport
    Do you have a link to that? Having trouble finding it
  5. Feb 13, 2019 at 5:56 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You can fit up to a 33” under the bed
  6. Feb 13, 2019 at 6:59 PM
    Pigpen
    Dan
    Northwest Montana
    My Toyo M55 255/85/16 measured , when new, at 33.5" and fit in the stock location. You just have to gently massage the retainer tabs out slightly with a BFH. Don't over do it! The tabs bend out pretty easy, but they won't bend back so easily if you bend them too far. This is the voice of experience talking. The tire sits against my stock hitch and leaves plenty of clearance for the rear diff and exhaust. The exhaust tip doesn't ever get hot - so it isn't a big deal even if it touches the exhaust.
    Blu4.0[OP] likes this.
  7. Feb 13, 2019 at 7:06 PM
    Dropitmore
    Andy
    Downey, CA
  8. Feb 13, 2019 at 8:01 PM
    DirtTaco
    DirtTaco Well-Known Member
    I have 285 75 16 duratrac under the bed two years no problems. Flatten out the stock tire retainer as stated above.
  9. Feb 14, 2019 at 6:34 AM
    TheBigKahuna
    TheBigKahuna Well-Known Member
  10. Feb 15, 2019 at 9:29 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    TheBigKahuna has spoken :yes:
  11. Feb 15, 2019 at 9:36 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    a couple straps over the tire to the corner tie downs, and one across the tire to the bed rail worked for me. This was the old setup
