Spare tire bracket removal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Dec 9, 2017.
  1. Dec 9, 2017 at 10:40 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    I took my spare tire and put it in the bed. The 2 brackets that held the tire in place, leave on or take off?
    95 Tacoma
  2. Dec 9, 2017 at 10:42 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    leave on
  3. Dec 9, 2017 at 11:10 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I took mine off. Cleans up the underside of the rear end. I don’t plan on putting my spare back under there so I removed it.
  4. Dec 9, 2017 at 11:11 AM
    vettehigh
    Jon
    Upstate, NY
    That's what my plan is or was. It's just 2 bolts on each bracket right?
  5. Dec 9, 2017 at 11:14 AM
    Trapperr
    Reno, NV
    Yes 2 bolts per bracket and I believe the nut is welded to the bracket if I recall
  6. Dec 9, 2017 at 11:16 AM
    vettehigh
    Jon
    Upstate, NY
    How do you get the nut off then?
  7. Dec 9, 2017 at 11:17 AM
    Trapperr
    Reno, NV
    Good question. Might have been a bolt that sandwiches to the cross piece? It’s beeb awhile since I took them off. They’re in the garage. Now you got me wanting to look at them but I’m away from the house.
  8. Dec 9, 2017 at 11:18 AM
    vettehigh
    Jon
    Upstate, NY
    I'll check this afternoon
  9. Dec 9, 2017 at 12:16 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    4.5" grinder with a Cutting wheel .
    I just can`t get into crawling under the truck to check the air pressure
    Then I never had a mount that was not rusted solid and the tire flat
  10. Dec 9, 2017 at 12:25 PM
    vettehigh
    Jon
    Upstate, NY
    Heck with it then. If it was just an unbolt, I'd do it right now.
  11. Dec 9, 2017 at 12:26 PM
    Trapperr
    Reno, NV
    It is just an unbolt
  12. Dec 9, 2017 at 12:27 PM
    vettehigh
    Jon
    Upstate, NY
    Just unbolt the 4 nuts. Nothing else, no cutting or other BS?
  13. Dec 9, 2017 at 12:28 PM
    Trapperr
    Reno, NV
    Exactly. If was any harder than unbolting, I’d have been too lazy to do it haha
  14. Dec 9, 2017 at 12:30 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Let Us know how it goes
  15. Dec 9, 2017 at 12:47 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Take it off and mount an extra gas tank there!
    AKsavanaman and Trapperr like this.
  16. Dec 9, 2017 at 1:07 PM
    vettehigh
    Jon
    Upstate, NY
    I tried, but the nuts wouldn't budge. Not to mention, I have no leverage either.
    I'll take it to my exhaust shop mechanic and have him take them off, probably with air gun
  17. Dec 9, 2017 at 4:31 PM
    Trapperr
    Reno, NV
  18. Dec 9, 2017 at 5:15 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    You have to remove the bed to access the bolts from the top.
  19. Dec 9, 2017 at 7:36 PM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    I would think that it does add a bit of lateral stability to our already flimsy rear C channel frames.... I'd leave it i there unless you plan on putting something in it's place... I've got dreams of an aux tank, but dreams they must stay for now:(
  20. Dec 10, 2017 at 5:47 AM
    vettehigh
    Jon
    Upstate, NY
    When I was under there, I thought the same. I'll leave it for now. Thanks all
