Spare Tire Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tackz, Sep 3, 2010.
  1. Sep 3, 2010 at 5:40 PM
    Tackz
    Tackz [OP] Well-Known Member
    Wellington, FL.
    '14 TRD Sport DC/LB 4x4
    What do you use to turn the screw to remove the spare tire in a 2007 toyota tacoma?
  2. Sep 3, 2010 at 5:52 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    is this a serious question?
  3. Sep 3, 2010 at 7:18 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If someone who has changed their oil numerous times and then accidentally drains the tranny by mistake...I could believe it's a serious question.
    So the answer to the OP's question is....
    Drum roll, please.:D
    The tool that came with the truck for lowering it. Got Owner's Manual? If not, you'll find the outer edge of the rounded hook on the end of your jack's crank will fit in the slot. Crank it up/down just like you'd crank the stock jack.
  4. Sep 3, 2010 at 7:25 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    09 Black Access Cab 4x2
    Some stuff
    Good info, Hope I never need it. If so, thanks guys.
  5. Sep 3, 2010 at 7:38 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    If you've never lowered the spare I'd recommend doing it during daylight hours just to see how it works and carry a flashlight if you ever need to do it at night...kind of a pita.
  6. Sep 3, 2010 at 9:16 PM
    Tackz
    Wellington, FL.
    yeah, i figured it out about 30 seconds after the original post. Brain fart. Never had to take it out before & wasn't sure if there was something to use other than the stock jack tool set.
