Spare tire help
Discussion in 'Wheels & Tires' started by The Big O, Mar 30, 2012.
  1. Mar 30, 2012 at 6:47 AM
    The Big O
    The Big O [OP] Well-Known Member
    James
    Lyndhurst, New Jersey
    '11 Taco 4x4 SR5 - Black
    I'm trying to take my spare tire down ('11 Tacoma) and I seem to be having a problem. I watched the how to video by acozzens and did some searching to try to solve my problem. I have come to the conclusion that my truck is missing the piece that receives the hook to lower the spare. Here is what other trucks look like and here is what mine looks like...
    First from a helpful thread about spares...
    Next from the how to video
    Here is mine...
    I called the dealer and I'm going there to get it checked out. If I'm missing something please save me the embarrassing. If I'm not then go check your spare because I would be SOL at midnight on a dark road compared to my driveway on a Friday morning.
  2. Mar 30, 2012 at 6:59 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    the hook end does not engage into like it does on the bottle jack. the hook has to act like a flat head screw driver and lower the tire as you turn the round bolt head.
  3. Mar 30, 2012 at 7:04 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
  4. Mar 30, 2012 at 7:06 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Yep. The hook will set itself into that slot and you just turn the handle. Righty tighty lefty loosy. Its a horrible design and a PITA to work with, but it does the job.
  5. Mar 30, 2012 at 7:17 AM
    The Big O
    James
    Well right before I left to go to the dealership I found this piece that must have fell out of the tow kit repair bag... They must have changed the design for the 2011, it was really easy now that I have this adapter.
    Also I saw this when I dropped my spare... There must be some serious rubbing going on with that spare tire... I'm going to put some sort of buffer between the tire and the truck before I put it back up..
    Anyone else?
  6. Mar 30, 2012 at 7:27 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I cant see your pics
  7. Mar 31, 2012 at 11:56 AM
    The Big O
    James
    Sorry about the pictures I figured it out now... Anyone else have that happen to their spare?
  8. Mar 31, 2012 at 12:16 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    As soon as I saw your photo I could see that they made the spare lockable so nobody could steal it! That is a locking lug in there instead of the previous slot. Good that you found the key that goes on the end of the crank!
    Also, my spare had the same wear in the sidewall... I flipped it around but that was mainly to have access to the fill valve on the spare to add air if it ever needs it. (without dropping it to the ground)!
