Spare tire in roof basket ideas
Discussion in '1st Gen. Tacomas (1995-2004)' started by meatman, Jun 11, 2013.
  1. Jun 11, 2013 at 5:47 PM
    meatman
    meatman [OP] I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    More than the wife knows!
    I'm looking in relocating my spare tire to my roof basket. I spent sunday adding extra support to the bottom and have several ideas as to tie down the spare (ratchet straps, j-hook and wing nut) anyone have any other suggestions?
  2. Jun 12, 2013 at 9:42 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    My suggestion is : Don't do it.
    It will raise your center or gravity (more likely to tip over in off-camber conditions).
  3. Jun 12, 2013 at 2:55 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    West Coast
    03 Access Cab TRD 4X4 V6
    19 Gallon Auxillary Fuel Tank Beeper Dampened 12V's always hot LED Reverse Lights Snug Top Hi Liner Camper shell Sleeping Platform w/ drawers Deck Plate Mod Kuat Core Hitch Rack OME All Around w/ AAL Built in 800 Watt Inverter Gray Wire Mod 2Lo Mod 235 85 R16 General Grabber AT3's Hella 500 FF's Relayed into High Beams 42" LED Light Bar Relayed into High Beams Reverse Camera Paranoid Fabrications Switch Panel Under Hood LED Light Sway Bar Delete 1996 Yamaha YZF 600 Daily Driver
    I'm interested in this as well. I'd like to be able to carry an extra spare up there. My main concern, as Tan4X4 pointed out, is raising the center of gravity. My camper shell is 3 inches taller than my cab as it is. The top is at about 6'6".
  4. Jun 12, 2013 at 7:49 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    X2...
    not to mention it's a bitch to unload and load that tire up there...
    especially if it's bigger then stock.
    Had a friend that got a flat on the trial once.
    Was just a 33"... but If I wasn't there to help assist...
    the fubar'd tire would have never made it back onto the rack.
    Unloading wasn't too difficult...
    just pushed it over the side...
    would have sucked if it had took a bad bounce tho' :eek:
    I say neh on the racks and top heavy chit if you wheel yer junk.
    But to each their own
  5. Jun 12, 2013 at 10:22 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    Clemson
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Window Rain Guards Bed Liner Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges
    and you'll just be adding a sail for the wind to catch and decrease your mpgs. ideal place to put is on a swing out arm that is just after the tail gate. keeps it out of the wind and from getting hung up while wheeling
  6. Jun 13, 2013 at 10:19 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    My guess is that the OP is aware of the issues mentioned, because obviously the extra weight up high will change the COG, and increase wind resistence and be more difficult to get to when needed. Yet still he wants to do it, that is his prerogotive, he's looking for suggestions for mounting.
    J-hook/wingnut combo is the right idea but not secure enough IMO. I would weld a plate with a large captured nut to the floor of your rack and use a large diameter threaded rod with a T-handle to bolt it to the basket.
  7. Jun 13, 2013 at 2:44 PM
    meatman
    Greg
    Murphy N.C.
    Thanks everyone for your input! As Adam said i have considered all the issues mentioned but may scrap the project only because after fitting my stock spare in the basket i realized that i will only have enough room (side to side)in the basket for the 265's im runnimg now and not 285's i will get when these wear out.
