Spare tire lift-There has to be a better way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtdog, Oct 12, 2012.
  1. Oct 12, 2012 at 2:59 PM
    vtdog
    vtdog [OP] Well-Known Member
    NH
    I am going on a long trip and decided to check the air in the spare. What a PITA to try and get the rod end into the crank piece (I have curved type which fits into a "slit"). There simply has to be a better way to do this. It took me 10 minutes of screwing around to finally get the parts lined up so I could crank the spare down. There seemed to be no way to line things up except by trial and error. I have had other vehicles with crank type spares and never had this issue.
    Is there an aftermarket tool, or some trick that I missed that would make this go easier?
  2. Oct 12, 2012 at 3:27 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Next time flip your tire over do stem is facing down. That way you can just go undernath and check or add air
  3. Oct 12, 2012 at 3:28 PM
    monsterkx2fiddy
    A you can tell I need a new phone.
  4. Oct 12, 2012 at 3:38 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
  5. Oct 12, 2012 at 4:04 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Yeah try doing that at 4:00am in the mountains on a dirt road in the middle of the forest. Used the bottle jack too...
  6. Oct 12, 2012 at 5:37 PM
    Gregg
    Gregg Well-Known Member
    Gregg
    New Jersey
    2010 Access Cab TRD Sport 4x4 Magnetic Grey
    I would have rather Toyota made you crawl underneath the truck and unscrew the spare tire manually than design such a piece of crap mechanism for getting the spare down. I have never seen such a poorly designed way to get to the spare tire. The rod to lower it is weak and trying to find the notch to put it in is a pain in the ass, and that is in good weather. Next time I take it down I will do the PVC pipe mod, but Toyota should have designed a more user friendly way to get to the spare tire.
  7. Oct 12, 2012 at 5:38 PM
    The Traveler
    SoCal
    Easier for you means easier for thieves.
  8. Oct 12, 2012 at 5:47 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I use a flashlight, it allows me to see in there and I can line them up pretty quicly
  9. Oct 12, 2012 at 5:55 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Do the mod, and flip the tire. Works great.
