Spare tire missing from underneath truck!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BayTaco, Oct 24, 2011.
  1. Oct 24, 2011 at 2:58 PM
    BayTaco
    BayTaco [OP] Well-Known Member
    Nor Cal
    08 TRD RT 4WD DBL CAB SB
    2.5" Lift, 265/75R16 A/Ts, aFe Pro Dry S, ARE Shell, Magnaflow
    Hello TW, I have a predicament and maybe someone here can shed some light. As the tile says my spare is missing and I am not certain how it happened. The truck was parked at the marina yesterday, while I was out fishing. After getting back and making the trip back home the TMPS light on the dash came on. I thought I had a puncture, after pulling over and checking nothing seemed wrong so I made it home. Once home I checked again and nothing, so I wandered underneath the truck to check the spare and it was gone!! At first I thought it fell off the mount, because I went through a rough road, which was very bouncy, so I made the trip back to the marina and looked for it..no luck. Then I started thinking maybe it was stolen :mad:, but the cable is not cut. So WTH happened to my spare. Can it just fall off?? The distance between the mount and the frame is the same width as the spare would be and if this is the case there is a huge design flaw with the mount. Did some ahole steel it? Probably the latter and it is driving me nuts and I am livid at the thought of it. What are my options here and how much is this going to cost me to replace. Thanks in advance.
  2. Oct 24, 2011 at 3:03 PM
    mikesfarm
    mikesfarm Well-Known Member
    Florida
    2025 4wd Tacoma SR5 DC
    I had a buddies spare tire lift cable break and drop his spare on the interstate then he ran over the spare with his airboat trailer. It lifted the boat and trailer in the air and came down hard, but no harm done.
  3. Oct 24, 2011 at 3:04 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    You would know if it fell off while driving! Since the light came on, it was removed just before that location!
  4. Oct 24, 2011 at 3:16 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    There's a TPMS sensor in the spare? Awesome.
    Sorry to hear about your loss, OP.
  5. Oct 24, 2011 at 3:24 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    08tacoma4x4 5spd 4cyl
    afe cold air intake,tornado fuel miser,body armor front bumper,dual magna flow exhaust,blacked out factory rims and fender flares,baja lights,cooper ATR tires,Gforce,hood scoop,peel n seal bed cover,chrome nerf bars
    You must have a dishonest tacoma owner in the area . Sounds to me like it was taken off and they raised the hanger back up so u wouldnt see it or hear it dragging when u left. I knew a guy that use to take ppls spare tires till he had eneough to replace his wore out tires on his chevy:mad: as far as i know hes still doing it.
  6. Oct 24, 2011 at 3:32 PM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    You know a guy that does this and you haven't reported it to the authorities?
    Knowledge about a crime and not reporting it is, in fact, a crime in itself. Report that asshat.
  7. Oct 24, 2011 at 3:38 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    shit got stolen
  8. Oct 24, 2011 at 3:45 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Are you always this useful?
    :rolleyes:
  9. Oct 24, 2011 at 3:50 PM
    BayTaco
    Nor Cal
    Yes I am sure the spare was there before, the TMPS light would have come on if I lost it before then.
  10. Oct 24, 2011 at 3:50 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    Are you always this sexy?
  11. Oct 24, 2011 at 3:51 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    I can assure you, I am always this sexy.
  12. Oct 24, 2011 at 3:52 PM
    BayTaco
    Nor Cal
    That sucks, glad no harm was done. The cable in my truck looks fine and it is still attached.
  13. Oct 24, 2011 at 3:53 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    There's no sensor on the spare... at least, I seriously doubt it's active/used. Anyone care to confirm/deny?
  14. Oct 24, 2011 at 3:54 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    there is in my spare
  15. Oct 24, 2011 at 3:55 PM
    BayTaco
    Nor Cal
    The funny thing is the light didn't come on when I was leaving the parking lot, where I would assumed someone had plenty of time to steel it. It came on when I was on the highway heading home. That is why I assumed it fell off and yes I would have know if that happened, because the traffic behind me.
  16. Oct 24, 2011 at 3:57 PM
    BayTaco
    Nor Cal
    I am thinking so..and I heard of this being done. TOTAL B/S!!! You should report the guys who is doing this. It is not fair I worked hard for what I have and they should too :mad:
  17. Oct 24, 2011 at 3:59 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    And it actually sets off the TPMS if your spare gets low...?
    /me runs out to drain his spare tire of air...
  18. Oct 24, 2011 at 4:00 PM
    chaotichoax
    chaotichoax Well-Known Member
    Jeff
    Howell, NJ
    '11 MGM DC/SB TRD Sport
    no sensor in my spare
  19. Oct 24, 2011 at 4:01 PM
    BayTaco
    Nor Cal
    Thanks. There is a sensor in my spare, well there was! I believe it was standard on our trucks from 06'.
  20. Oct 24, 2011 at 4:01 PM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    they should work hard for what you have?
    :confused:
