Spare tire missing from underneath truck!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BayTaco, Oct 24, 2011.
  1. Oct 24, 2011 at 4:02 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I got that tire thing on my dash board and it went away when I put air in the spare so - yes there must be a sensor on the spare.
  2. Oct 24, 2011 at 4:02 PM
    ToyTaco09
    ToyTaco09 Well-Known Member
    Texas
    09 TRD Sport DC
    I've had a spare stolen from my last pickup, but the wire was cut. I didn't notice until I needed it, which really sucked. Now I have a cable lock around the spare on my Tacoma so this doesn't happen again. Maybe someone took the time to wind yours down and then wind it back up?? Odd.
  3. Oct 24, 2011 at 4:08 PM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    Hrm. Seems dubious. I've had some people say there is, others say there isn't. I'm going to drop my spare tonight and see what happens.
  4. Oct 24, 2011 at 4:10 PM
    george3
    New Jersey
    Well, It didn't go away when I filled the 4 on the ground - only when I filled the spare.
  5. Oct 24, 2011 at 4:21 PM
    BayTaco
    BayTaco [OP] Well-Known Member
    Nor Cal
    08 TRD RT 4WD DBL CAB SB
    2.5" Lift, 265/75R16 A/Ts, aFe Pro Dry S, ARE Shell, Magnaflow
    People should work hard to fulfill their wants and needs not steel from others!!!
  6. Oct 24, 2011 at 4:22 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    IIRC they stopped putting sensors in the spares on the '09 and up. On my '08 there is, I have had to add air to get the light to turn off.
  7. Oct 24, 2011 at 4:24 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    That's f'd up. Sorry to hear that happened to you.
    Glad you have the TPMS in your spare. At least you KNOW you're missing your spare. Imagine being stranded with a flat tire and only then finding out it's gone.
    TPMS in spare rocks. My '10 has one too. Got me all confused one day when the spare ran low on pressure lol
  8. Oct 24, 2011 at 4:25 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    They discontinued the TPMS in the spare for 2010 models and later.
  9. Oct 24, 2011 at 4:28 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Ok, one guy says disabled on '09+. One guy says '10+. A completely different guy with a 2010 says it works...
    Does anyone have anything definitive? I'm still going to drain my spare just to see what happens :D.
    Sorry OP, kinda jacking your thread with this whole spare tire TPMS talk.... makes me wonder!!
  10. Oct 24, 2011 at 4:29 PM
    ottawaguy
    ottawaguy Member
    Ottawa, Canada
  11. Oct 24, 2011 at 4:41 PM
    BayTaco
    Nor Cal
    Thanks, yeah I am glad I found out now than when I needed my spare and that is thanks to the TMPS sensor!
  12. Oct 24, 2011 at 4:48 PM
    george3
    New Jersey
    Well, There ya go. I have an '08.
  13. Oct 24, 2011 at 4:48 PM
    BayTaco
    Nor Cal
    Yeah I guess it is not that uncommon. I never knew, if I had I would have invested in a lock :( Thanks
  14. Oct 24, 2011 at 4:54 PM
    BayTaco
    Nor Cal
    This is what I am trying to do now. Anyone have a spare rim with the sensor they want to get rid of?
  15. Oct 24, 2011 at 4:59 PM
    #35
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    Sorry to hear about your missing tire, I to think it was stolen.
    I think the TPMS must only do checks after you hit a certain speed and/or distance which would explain why it took so long to come on.
    I run snow tires without sensors in the winter. If I don't drive far the light never comes on. It only comes on once I am about 20 minutes from home and the speed limit is over 100 km/h.
    Not sure if it is the distance or speed that causes it to do a check, but I can literally go weeks without the light coming on.
    All this leads me to believe it was taken when you were parked.
    Shawn
  16. Oct 24, 2011 at 4:59 PM
    #36
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep...they stopped putting the sensors in the spare back around 09.
    OP... your more than likely looking at a couple hundred for the wheel, tire, new sensor, and re-calibration. Sorry to hear it got stolen...run a cable around your spare and the frame and lock it up.
  17. Oct 24, 2011 at 5:16 PM
    #37
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    crazy story man. hate to say it doesnt seem too hard to steal them but i kno some tacos some with spare tire locks..
  18. Oct 24, 2011 at 5:16 PM
    #38
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    Now get a fabtech tire mount for the back of your bed and buy a lock for safety
  19. Oct 24, 2011 at 7:05 PM
    #39
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    That's odd, because my '11 has a sensor in the spare. I've seen it in person when I dismounted the tire from the wheel, and I've seen it light up my dash when the spare gets low. Also, if you do the cable thing... make sure it's a damn good lock or a weatherproofed lock or when you need that spare you're gonna need bolt cutters too... One of my friends did this and the lock froze shut because of all the crap that had gotten in it from being underneath the truck.
  20. Oct 24, 2011 at 7:31 PM
    #40
    khx73
    khx73 Well-Known Member
    Saint John NB, CAN
    11 MGM DCLB TRD Sport +leather
    Rear camera anytime switch, 4x4 Illuminated Switch (from rcbs204) , rear view mirror lift bracket (from ImMrYo), 75 cent tailgate anti-theft. Technically not mods but give me a break I'm trying to fill space here... OEM Leather pkg, keyless unlock & ACC chime silence, BakFlip G2, Ultra Gauge EM, WeatherTech floor mats, OEM roof rack
    Pretty sure that's how the TPMS works.. there's a delay before it scans and reports the status. You have to be up to a certain speed/and or length of time. See the manual for details, I'm not sure of the numbers right now.
    Sucks you got ripped... Making me think about locking mine up somehow now..
