Spare tire mounted upside down?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sarhog, Jun 19, 2017.
  1. Jun 19, 2017 at 4:13 PM
    Sarhog
    Sarhog [OP] Well-Known Member
    Greer, SC
    2017 Tacoma Sport Rally
    I just got a 2017 SR access cab a couple weeks ago. I was crawling around trying to see if I have TPMS (I don't) when I noticed that the spare tire is mounted in such a way that you cannot check the air pressure without lowering it. Is that right? Seems odd to mount that way, I can think of no benefit to it. I lowered it and mounted it the "proper" way and it fits just fine.
    Are all of them mounted wrong?
    John Z
  2. Jun 19, 2017 at 4:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    You do have TPMS. Don't know whay you expected to see crawling around, sensors are in the wheels as part of the valve stem assembly.
    See if the spare will fit properly when flippped so the stem is down. If not, buy a 12" valve stem extension, install it and route thru the wheel so you can keep air correct. I've had one on my '04 Highlander since new.
  3. Jun 19, 2017 at 4:31 PM
    Sarhog
    Greer, SC
    I was looking for stickers on the wheels that say "caution, TPM sensor" or some such verbiage. There are none that I've found. Do ALL 17's have TPMS? My truck is a base model, with the only option being the utility package. There is no place on my dash display for it either, unless it's just a caution light.
    As far as mounting the spare properly, I did, and it fits fine.
  4. Jun 19, 2017 at 4:40 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 2007 has sensors in all 5 wheels. If my spare gets low the TPMS light comes on. This was changed at some point after 2007.
    As far as I know ALL spare tires are mounted that way. My F-150 is as well as all previous trucks are like that.
    It is possible to get a tire gauge on the spare. You just have to be a little flexible.
    TRDSport10, Oldman808 and shakerhood like this.
  5. Jun 19, 2017 at 4:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    No stickers.
    No sensor in spare, just in the 4 on ground.
    Check out your owners manual to learn how it works.
    TRDSport10 and cblow5 like this.
  6. Jun 19, 2017 at 5:02 PM
    Sarhog
    Greer, SC
    My owner's manual says "if equipped".
    pray4surf likes this.
  7. Jun 19, 2017 at 5:06 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    TREAD act. All new vehicles sold in US must be equipped with TPMS, so your truck has it. Whether or not the spare does....
    Sidney Vicious, cblow5 and Sarhog[OP] like this.
  8. Jun 19, 2017 at 5:10 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Spare doesn't.
    TRDSport10 likes this.
  9. Jun 19, 2017 at 5:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    You can prove it 1 or more of 4 simple ways.
    Look at the valve stem. TPMS are not like traditional rubber stems.
    Let 6 lbs of air out of one tire. The light will come on when you meet the driving conditions required
    Look unnder the dash and find the reset button.
    Turn your key 'on' and the warning icon shown in your manual will illuminate as part of the test cycle.
    My 13 base 5 lug, the lowest of the low, has it. And I've never seen a nanny system discontinued once implemented :(
  10. Jul 4, 2017 at 8:18 PM
    snowcrabpg
    snowcrabpg Well-Known Member
    Houston
    2015 Tacoma TRD Off Road
    PelfreyBilt Hidden Winch Mount Smittybilt X20-10K Armor Tech Off Road hilift bed mount RotoPax Tacoma bed rail mount MaxLiner weatherproof floormats Color Matched front grill Plastidip rear bumper Interior LED lighting Waiting full RCI skids roofrack suspension
    So those with a full size matched wheel spare, are they not using TPMS in that spare?
    I'm asking because I just got 5 new wheels for my gen2 but this thread is newish and seems fairly relevant.
  11. Jul 4, 2017 at 9:26 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My old 08 also had a Sensor in the Spare.
    Oldman808 and tcjacado like this.
  12. Jul 4, 2017 at 9:28 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    I just got a full sized matched wheel spare last weekend. Opted for a standard valve since the spare doesn't have tpms.
    As mentioned earlier, if you're unsure if your spare has tpms or not lower the pressure down to 20-25 psi and check for a warning light on the dash.
  13. Jul 5, 2017 at 6:03 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    the reason spare rims are mounted that way is so the face of the wheel is not facing the ground to damage the face from road debris. this is more for the vehicles that have a nice wheel as a spare.
  14. Jul 5, 2017 at 6:22 AM
    htgreen3
    htgreen3 Well-Known Member
    Central Virginia
    2015 TRD OR
    the spare on my 2015 ortdr has a tpms in the spare, found out by light coming on, checked the 4 on the ground, all good, checked the spare, it was low, put air in, light goes out after a short drive. ask dealer, yes it has tpms on the spare
    snowcrabpg likes this.
  15. Jul 5, 2017 at 6:46 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    pretty much this
    but it is so when you drop it, you can get the hook out
    if the face of the wheel was facing down, when you drop the tire it's harder
    to unhook it or rehook it if it's in the dirt
  16. Jul 5, 2017 at 6:48 AM
    shakerhood
    Southern Ohio
    Plus the valve stem is protected by facing up too.
  17. Jul 7, 2017 at 7:32 PM
    Sarhog
    Greer, SC
    It is protected, but also inaccessible. :annoyed:
    I've flipped my spare so that I can check/add air to it easily.
    ShemRahBuck and cliffyk like this.
  18. Jul 8, 2017 at 4:22 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I've always flipped them around. Why Toyota did that, who knows?
  19. Jul 8, 2017 at 9:20 PM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    Mine was flipped that way after i got a flat and had to use my spare. I didnt know it until i started to hear rattling a day after. Found it to be a bit loose, and i tightened her up. Two days later, same thing... I ended up flipping it back to the way it said in the manual and no more issues with it coming loose.
  20. Jul 8, 2017 at 9:26 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Most all spares come from the factory (not just Toyota, but all trucks) "upside down". And all vehicles sold in the US since 2008 are required to have TPMS. Though not all systems use sensors in the wheels. A lot of European cars use the wheel speed sensors to detect when a tire loses air.
