Spare tire mounted upside down?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sarhog, Jun 19, 2017.
  1. Jul 8, 2017 at 9:33 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    This is an interesting thread -- I think I had better take a better look at my owners manual!
  2. Jul 8, 2017 at 9:36 PM
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    I always flip valve side down. Learned that from the coach who taught us drivers' ed 30 years ago. Funny.
  3. Jul 8, 2017 at 10:21 PM
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Why do you need to check and air up your spare when it's not being used? Just buy a small compressor to keep in your truck and you can fill it if/when you need it. You can get a basic compressor for cheap (~$20).
  4. Jul 9, 2017 at 4:44 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I just put an extra 10 psi in my spare as a buffer against loss over time.
  5. Jul 11, 2017 at 1:58 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Any specific recommendations? I'd like a decent air compressor to keep in my truck at all times - to adjust tire pressure when needed in offroad situations (moreso to put the air back in before hitting the pavement) and when driving in diff temps/altitudes. Also would prefer to have the AC/DC option as we have several inflatable items (rafts, etc.,) and would prefer to use the AC in the truck bed vs. being tied to the DC in the cab.
  6. Jul 11, 2017 at 2:06 PM
    oldschoolczar
    '16 DCSB TRD OR
    I just got a little cheapo. It's D.C. And takes awhile to air up, but it's perfect for just topping off the spare and stuff. It's pretty slow so might be a pain in the ass to air up all 4 tires after off-roading, etc. But the price was right. I'll see what kind it is when I head back out to my truck after work shortly. Super small and fits under the backseat.
  7. Jul 11, 2017 at 7:19 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I go valve stem up to protect the stem and the face of the wheel. I use my spare in the rotation, so all tires get checked whenever I rotate.
    shakerhood likes this.
  8. Jul 11, 2017 at 8:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Even though I don't use my Spare in my rotation, I always pull it down a couple times a year to clean and make sure the pressure is good.
  9. Jul 11, 2017 at 8:11 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Reason they put them face up is to make getting the spare off easier.To protect the valve stem and to keep water , dirt and debris sitting inside the back of the rim causing rusting out on a steel spare. Allso mud and debris on the inside of the rim will cause a perfectly balanced tire to become unbalanced.
    GilbertOz and shakerhood like this.
  10. Jul 11, 2017 at 9:23 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    The spare is upside down to protect the nice rims from road debris, also keeps the metal arm that holds the spare from nicking/wrecking a nice rim.
    U have some sort of tpms system...
    The only way to properly have 5 tpms sensors is if you have the recalibration tool to tell the ecu which serial numbers are being used...
    ie you would have to remove all your tires write down the serial numbers on the current 4 tpms add an extra tpms and serial number and when u rotate your spare in or use it you have to plug in your recalibration tool to set the tpms serial numbers in the ecu.
  11. Jul 12, 2017 at 2:14 PM
    nartmot
    nartmot Well-Known Member
    So does this mean all the guys running spares with matching tires and rims are not rotating their spare in? Sorry if thats a dumb question. Just wondering for when I get my 4Runner wheels. If its a huge PIA to rotate the spare in, I think I will stick to the stock spare and just by 4 wheels instead of 5. What do you guys do?
  12. Jul 12, 2017 at 2:16 PM
    Rackness
    Rackness Well-Known Member
    Maryland
    17' Tacoma
    Working on it.
    Mine was inside out!!:anonymous:
  13. Jul 12, 2017 at 2:22 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  14. Jul 12, 2017 at 3:33 PM
    Broccoli
    Airdrie Alberta
    It just means that you have to set the tpms to read the new tire and not the one cycled out, unless u want to know what pressure your tire is under the truck(spare) and not on the ground.
  15. Jul 13, 2017 at 5:55 AM
    #35
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    I cant remember the year for sure, but the DOT mandated TPMS sensors in all vehicles starting 2010 or so. Every single 2017 vehicle sold in the US aside from some commercial vehicles, has TPMS.
