Spare Tire Mounting Location V-Nose Enclosed Trailer
Discussion in 'Towing' started by blueburban6, Mar 22, 2012.
  1. Mar 22, 2012 at 6:18 AM
    blueburban6
    blueburban6 [OP] Well-Known Member
    Nick
    Northern New Jersey
    2011 SR5 Double Cab 4x4
    I am looking for a good spot to mount my spare tire on my v-nose enclosed trailer. Does any one have any good suggestions where to mount it?
  2. Mar 22, 2012 at 6:27 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I am assuming you are talking about your truck spare tire on the trailer??
    Is there space under or on the tongue?? Or put some bolts that are the size of the lugs thru the wall of the trailer and bolt it on up right?? Mount it inside one of the doors??
  3. Mar 22, 2012 at 6:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd mount it on the outside of the trailer wall on the V-nose or over the fender unless you want it taking up room inside the trailer. Brace the interior side of the wall as necessary for the extra weight.
  4. Mar 22, 2012 at 6:56 AM
    blueburban6
    Nick
    Northern New Jersey
    Its the spare for the trailer itself. I don't want to take up room on the inside of the trailer and the tongue of the trailer is too short to mount it there. The outside wall of the v sounds like it may have some potential.
  5. Mar 22, 2012 at 8:10 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    If you use the V nose as a mounting spot, mount it high enough to clear tailgate if it is lowered. Also it it will be more out of the way up high. As others have said, reinforce the inside wall to hold the spare.
  6. Mar 22, 2012 at 8:41 AM
    blueburban6
    Nick
    Northern New Jersey
    Any recommendations for reinforcing the wall for the spare?
  7. Mar 22, 2012 at 8:47 AM
    Pugga
    Massachusetts
    Plywood or heavy gage sheet metal as a backer plate on the inside of the trailer. It kind of depends on how flimsy the walls are to begin with but either of my suggestions should work fine. You just don't want the bolts to pull through the side of the trailer wall.
  8. Mar 22, 2012 at 8:57 AM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    I would use at least 5/8 plywood.....
  9. Mar 22, 2012 at 10:25 AM
    blueburban6
    Nick
    Northern New Jersey
    Thanks for the input. I appreciate it.
