Spare tire not matched?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RBaptist, Dec 2, 2018.
  1. Dec 2, 2018 at 11:35 AM
    RBaptist
    RBaptist [OP] Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    googled it and didn’t see anything come up but I was under my 2017 Sport today torquing the u bolts (they were indeed loose) and noticed that my spare is a Firestone but my tires are Toyo A30s.
    Normal?
  2. Dec 2, 2018 at 11:39 AM
    tcjacado
    tcjacado Well-Known Member
    I have seen this at quite a few dealerships
    I wouldn't say it normal more than just a common practice.
  3. Dec 2, 2018 at 11:45 AM
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    What's the common practice? The dealership swaps out your spare tire hoping you don't notice?
    Or the factory just has extra Firestones left over? I didn't realize the 2016 came with Firestone.
  4. Dec 2, 2018 at 11:46 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    It was probably just left over Firestone stock from the 2016 models. They probably assume itll dry rot before seeing any real use anyway. I doubt people are doing 5 tire rotations with the spare rim
  5. Dec 2, 2018 at 11:47 AM
    Zulupapa
    Zulupapa Bah-Weep-Gragnah Weep Ni Ni Bong
    Waterloo Region Canada
    2017 Tacoma TRD Sport Inferno
    Purchased my 2017 in January 2017 and had the same thing. Never put much thought into it as it is my spare.
  6. Dec 2, 2018 at 11:48 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Do all of the sports come from the Factory with Toyo?
  7. Dec 2, 2018 at 11:48 AM
    Amanelot
    Amanelot Member
    Texas
    My 16 came with firestones
  8. Dec 2, 2018 at 11:51 AM
    shakerhood
    Southern Ohio
    I guess that would explain why the spares could possibly be different
  9. Dec 2, 2018 at 11:53 AM
    RBaptist
    Newnan, Ga
    Mine was a Q1 production 2017. I bet they threw an extra Firestone in there. Not that big of a deal, but what I’ve done in the past is save a few bucks by buying 3 new tires and putting the spare as the 4th. One of my old tires becomes the new spare. I doubt I’m sticking with the A30s next round anyway....just thought it was odd.
    shakerhood likes this.
  10. Dec 2, 2018 at 11:55 AM
    Amanelot
    Amanelot Member
    Texas
    I imagine the tires and wheels are probably pre-mounted before being sent to the assembly. They probably just had extra spares with the firestones when Toyo won the bid for the 2017 OEM tires. We have a few customers we send off premounted tires on new wheels to. When they are done building the equipment, they just bolt the wheels and tires on them and sell them.
    shakerhood[QUOTED] likes this.
  11. Dec 2, 2018 at 11:55 AM
    17TRD
    17TRD Well-Known Member
    2017 TRD OR 4X4 DCSB
    That sucks. My 17 TRD OR came with 5 matched Goodyear Wrangler AT w/ kevlar tires.
  12. Dec 2, 2018 at 11:58 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I think that’s standard on all off-roads
  13. Dec 2, 2018 at 12:00 PM
    Amanelot
    Amanelot Member
    Texas
    The Toyo and the Firestones are okay tires but are not very exciting. I'm sure you will switch to something better when wear the Toyo's out. You can find better tires for cheaper. I seem to have a hard time tracking down those A30s for some reason, makes me think it may be a dealer only tire. You know the mark up at the dealer will be stupid.
    RBaptist[QUOTED][OP] likes this.
  14. Dec 2, 2018 at 12:03 PM
    Amanelot
    Amanelot Member
    Texas
    Its a little bit different on an OR with AT tires then a Sport with street tires. Miss-matched AT tires is less acceptable then miss-matched straight tread HT tires.
    RBaptist[OP] likes this.
  15. Dec 2, 2018 at 1:59 PM
    cam1967rsss
    cam1967rsss Well-Known Member
    Mine too. Including spare...
  16. Dec 2, 2018 at 3:15 PM
    LS14ME2
    LS14ME2 Kind of a big deal
    In hiding, CA
    2017 SSM Sport DCSB 4x4
    Center console divider thingy, rubber bed mat and side steps for the wife.
    I have the 4 Toyo's with the Firestone spare as well.
    shakerhood and RBaptist[OP] like this.
  17. Dec 2, 2018 at 3:21 PM
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
    2016 limited spare came with same rim and michellen tire , 2018 trd pro came with metal rim.
  18. Dec 2, 2018 at 3:39 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    It's Perfectly normal pretty much across the TOYOTA line from what I've seen.
    The only exception would be if the wheel/tire option came directly from the factory. When a given trim comes with aluminum wheels/tires, the spare is a match.
    But if it’s a port or dealer install option, it will have the (different) tire/size that normally would come with that trim.
    But don’t sweat it guys, my port package installed option came with 17” wheel/tires and my spare is 16”, and if you remember those tiny doughnut spare tires, it’s the same principle. Just change it ASP because not only does it look terrible, but handling is bitch among other things.
    Hope that helps
    Cheers!
  19. Dec 2, 2018 at 3:43 PM
    RBaptist
    Newnan, Ga
    Oh man...I didn’t even check the rim size.
  20. Dec 2, 2018 at 3:52 PM
    Amanelot
    Amanelot Member
    Texas
    It's a 17 inch rim, same as the rest of your wheels. You can see it in your pic
    The hammer likes this.
