Spare Tire Question
Discussion in 'Wheels & Tires' started by elk340, May 28, 2011.
  1. May 28, 2011 at 7:26 PM
    elk340
    elk340 [OP] Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Hey guys, I just bought 4 17x8" Pro Comp 7089s and realized I did not account for the spare. I will be going with 285/70 R17 Duratracs. For those of you who upgraded your rims and tires, what did you decide to do with the spare? I don't know if I'm ready to drop $375 on the spare so that it can match. What did you do?
    I'm thinking of just getting a cheap tire with the same outside diameter as the Duratracs and mounting it on the stock 16" spare; however, one issue might be that the backspacing would not be the same as the pro comp rims.
    Your advice would be very appreciated.
    Justin
  2. May 28, 2011 at 7:33 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    full size matching FTW.
  3. May 28, 2011 at 7:37 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    do this. it doesnt matter if the backspacing isnt the same since ur just using it as a spare. i dont know if the 285s will fit under the truck though
  4. May 28, 2011 at 8:55 PM
    elk340
    Justin
    Ouray, CO
    I read that they will with a little fabrication. Apparently, there are a couple brackets that would need to be torched off. I'm worried 285s on the stock spare would cause rubbing on the UCAs without the correct back spacing. Hmmm.
  5. May 28, 2011 at 9:00 PM
    Mescalero
    Mescalero Beretta Taco
    Anderson, SC
    '15 DCSB TRD PRO Mag Gray
    let me know once you get ready to buy those duratracs...would be willing to get em for you round cost through our group buy if you'd like...
  6. May 28, 2011 at 9:26 PM
    elk340
    Justin
    Ouray, CO
    Tell me more. I've been pricing them and as of right now, the cheapest I have found are 4 for $969.51 w/taxes and shipping and handling.
    Justin
  7. May 28, 2011 at 9:46 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I put a 265/75R16 on the stock spare rim and it fits (barely) in the stock location. That's 1" smaller diam than my mounted tires, but I expect it'll get me back out to the road and to the next town.
  8. May 28, 2011 at 9:51 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have 33's and kept the stock as a spare. It will suffice to get me where I can take care of it properly.
  9. May 28, 2011 at 9:55 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Buy a spacer mount it under there with the spare.
  10. May 28, 2011 at 10:04 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I pounded the brackets out with a sledge to fit my 285 spare. Mounted it on the stock spare wheel. Only had to run it when Josh got a flat. He of course got a flat up front and it barely cleared. I don't think he could fully turn.
    It would be a PITA but you could always rotate a rear up front and mount the spare in the rear if you got a flat up front and your tire wouldn't clear. Save a lot of $$
    Could always buy a cheap wheeler's steel wheel with either 4.0 of 4.5 BS and throw a used 16" 285 on that.
  11. May 28, 2011 at 10:27 PM
    elk340
    Justin
    Ouray, CO
    Yeah, that would be a PITA. Might be worth buying a cheap rim with the right BS and a cheap 33" for it.
