spare tire question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Aug 10, 2011.
  1. Aug 10, 2011 at 7:23 AM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    Does anyone with 35's keep their stock spare tire? Can it be used safely? I don't even know if I could jack up my truck if needed in an emergency to change a tire
  2. Aug 10, 2011 at 7:39 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    I don't think your stock spare wheel will clear your spindle on a 6'' drop bracket lift.
    It's not good for a differential to run around with two very different size tires, either.
    You shouldn't have any issue lifting your truck. Use your drop bracket as the jacking point.
  3. Aug 10, 2011 at 9:58 AM
    Trachito
    Trachito Well-Known Member
    New Orleans
    same question. what have some of you guys done about this problem? i don't want to throw a spare in my bed cuz i usually have to haul shit. will a bigger one fit underneath? did yall get a bigger tire put on the oem spare rim? got a bigger rim and tire?
  4. Aug 10, 2011 at 10:03 AM
    Fodder4U
    Fodder4U Well-Known Member
    Mark
    The Colony, TX
    2011 SR5 Access Cab 4x4 Stock for now.
    Buy a good plug kit and a compressor to air it up. That is what I had in my Jeep once the gas prices went nuts and I took my oversized spare off to save weight.
  5. Aug 10, 2011 at 10:05 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    With an open differential, 2 different sized tires for a short distance to get yourself to a shop would not cause any issues. Not good for long distances but in an emergency situation you can do it. If you have LSD or posi this could cause problems.
    Carry a tire plug kit and a pump so you can repair the tire in most situations rather than needing the spare.
  6. Aug 10, 2011 at 10:15 AM
    Trachito
    New Orleans
    i have a plug/pump kit but i've been in a few cars where the tire was unrepairable. it's rare, and i hope to never be in that predicament with my truck.
    how can i find out if i have Limited Slip Diff? if i just have to go a short distance then i won't mind using my oem spare. i've thought about getting a used bigger diameter tire on the spare rim to minimize any issues while using it, but my spare is in excellent condition and i'd hate to get rid of it.
  7. Aug 10, 2011 at 10:19 AM
    Pugga
    Massachusetts
    F-150 Mod
    Should be a sticker on the rear diff that says "LSD Additive" or something to that effect telling you to use LSD additive when changing the fluid.
    It'd only be the rear that has limited slip unless you modified the front end on your own. Worst case, if you have LSD and shred a rear tire and only have a small spare, put one of the full size tires from the front on the rear and use the small spare in the front. You'll either have an open differential in the front or you're 2wd. Keep it out of 4wd with the smaller front tire and limp your way back to a shop to get it repaired.
  8. Aug 10, 2011 at 10:25 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    You can put one side in some loose dirt with the other side on pavement and gas it. If the dirt side spins and the pavement side don't it ain't locked. If it's locked neither side will spin or very little.
  9. Aug 10, 2011 at 10:29 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Rear tire carrier or some sort of roof mount?
  10. Aug 10, 2011 at 10:31 AM
    Pugga
    Massachusetts
    F-150 Mod
    Sounds more fun than looking at a sticker :D
    I don't have it though, so 1 tire fire for me :eek:
  11. Aug 10, 2011 at 10:46 AM
    Trachito
    New Orleans
    ah, i've looked for that before, now that you mention it. i'm good, no LSD.
  12. Aug 10, 2011 at 10:55 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Carry a plug kit, its way easier than changing a tire. I have a spare and a plug kit but I only use the spare if it's a sidewall puncture. I can leave the wheel on the car to plug it.
    The plug kit will cover most of your flats
  13. Aug 10, 2011 at 4:12 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I carry a plug kit. The spare was the first thing to go from the truck. I know it's nice to have it when needed but only needed a spare once in my many years of driving.
