Spare tire question
Discussion in 'Wheels & Tires' started by alx_alx_69, Jan 15, 2010.
  1. Jan 15, 2010 at 7:22 AM
    alx_alx_69
    alx_alx_69 [OP] Well-Known Member
    Alex
    Hope Mills, North Carolina
    I put 265/75/16 AT's on my stock Taco, but did not replace the spare which is a dunflop AT20 245/75/16, is this going to be a problem if I get a flat, common sense says yes but I am mechanically retarded, so how about a little expertise here
  2. Jan 15, 2010 at 7:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If you intend on useing the spare for any length of time, its a good idea to have the same size. Personally, I only use a spare (Same size or not) until the tire that was flat is repaired, or replaced, then the spare goes back to its spot.
  3. Jan 15, 2010 at 7:30 AM
    usmcgoose
    usmcgoose One shot is all I need
    Virginia
    05 Tacoma 4X4
    ^ I second. Just make sure you get the damaged tire fixed in a timely fashion.
  4. Jan 15, 2010 at 7:35 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    As long as you don't leave the spare on for an extended period of time, the suspension and differential will adjust and allow you to at least get it to a shop.
