Spare Tire Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by breakfasttaco93, Nov 27, 2017.
  1. Nov 27, 2017 at 12:48 PM
    breakfasttaco93
    breakfasttaco93 [OP] Well-Known Member
    Dan
    2017 Tacoma 4x4 TRD Off-Road
    2 probably dumb questions about 2017 Off Road spare tires.
    Does the spare come with a TPMS sensor?
    Will a 265/70/17 KO2 wheel fit in the normal spare tire spot?
    Thanks.
  2. Nov 27, 2017 at 12:54 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I got a nail in my tire a month ago and had to put the spare on. No TPMS on my 2016 Sport spare tire. Also, my spare is a steel wheel.
  3. Nov 27, 2017 at 1:03 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    No and yes up to a 285 will fit. Unless your switching out spare during rotations no need for tpms i wouldnt think. You will just get an error message until you go to tire shop.
    synaps3 likes this.
  4. Nov 27, 2017 at 1:25 PM
    TA2016
    Oregon
    Got a nail in the right rear tire. After putting on the spare, I put the nail tire in the bed and the TPMS read the pressure like it was still on the truck. I don't use the spare during rotations because the steel wheel looked pretty ugly on the truck.
  5. Nov 27, 2017 at 1:27 PM
    Friedtacolover
    Travis
    Ontario, Ca
    That funny you said this my tire shop broke my tpms and replaced it but put broke one in glove box. I went back to tire shop multiple times because it kept reading the old one about every minute and would switch from 32 psi to zero. Took 3 trips and about 6 hours of programming until the master programmer figured it out.
  6. Nov 27, 2017 at 1:35 PM
    TA2016
    Oregon
    I asked my tire shop to please be careful with the TPMS. Told them after they patched the tire, to throw it in the bed and I would put it back on myself. So they knew I was picky.
  7. Nov 27, 2017 at 1:38 PM
    breakfasttaco93
    Dan
    Thanks! I want to rotate 5 full size tires, should I get a 5th TPMS for the 5th tire?
  8. Nov 27, 2017 at 1:42 PM
    Friedtacolover
    Travis
    Ontario, Ca
    The one with tpms placed in spare storage will still read so you wont get an error message. But if the tire that was slare thats now on truck gets low you wont know. So thats up to you plan on spending about 125$ for a shop to install/program so your choice. Plus does your rim match? If not theres another 150$ for a rim. I would if i planned to rotate 5. But ive never done that and never will
    Does anyone know if a truck can have 5 tpms programmed? I wonder how it tells where the tire is as in front left vs front right. Best bet is to call local tire shop and get quote and ask the questions then decide if its worth it
  9. Nov 27, 2017 at 1:57 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    The 3rd gen only has room for 4 to be programmed. You can still add a 5th to your spare, but you would have to add/remove sensor IDs from the system through techstream or with a handheld programmer every time you rotate if you want the system to function as intended.
