Spare tire recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoman00, Nov 3, 2021.
  1. Nov 3, 2021 at 9:08 AM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    So I ran into a bit of predicament the other day. The wife and I were about 2.5 hours from home on a day trip, and one of my brand new tires with less than 3k miles on it picked up a shard of metal. I limped it to a local shop and they couldn’t patch/plug the hole successfully. It left me with a decision to make: throw the spare on knowing it’s quite a bit smaller than my 285/65/18 all terrains and roll down the road 200 miles home OR wait it out and stay the night out of town for a new tire to arrive in the morning. We chose the latter option.
    All of that makes me wonder what everyone up here does. I’ve heard running a smaller tire is OK if you move it up front (my flat was in the rear) but I’ve also heard it’s a bad idea in general if you’re going a long distance. So in the future if this happens, what’s the best option out there?
  2. Nov 3, 2021 at 9:12 AM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    Just buy a 5th tire to match your set. Swap it around occasionally to keep even wear
    kgilly, gudujarlson and Jojee117 like this.
  3. Nov 3, 2021 at 9:22 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    buy a fairly good used tire the same size as what you run and use it as the spare.
    DingleTower and Taco_mike73 like this.
  4. Nov 3, 2021 at 9:24 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I prefer to roll the dice, and keep the stock spare........
    Nymbus and gudujarlson like this.
  5. Nov 3, 2021 at 9:36 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I have all five wheels and tires matching and put the spare in the back under the shell. Much easier to get out.
  6. Nov 3, 2021 at 9:42 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I purchased five new wheels, five new TPMSs and five new 255's when I did my lift. The 255 (33") fits in the factory spare spot just fine. I do a five tire rotation every 5k miles.
    No sense being cheap with the spare.
    coma toy likes this.
  7. Nov 3, 2021 at 9:54 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    This is the answer...
    ...though this is what I'm doing. I'm only running 265s however.
  8. Nov 3, 2021 at 9:57 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Full size spare in the bed.
  9. Nov 3, 2021 at 10:21 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    The BEST method?
    5 matching wheels & tires.
    See below.
    Me as well.
    I had my Gen 2 for 15 years. The only time the original spare got lowered was when the frame was replaced after 9 years. Truck was reassembled and sold 6 years later with that same spare.
    The advantage of sticking with OEM tires is that when the typically rare event occurs, it's easier to simply replace the tire.
    Tocamo[QUOTED] likes this.
  10. Nov 3, 2021 at 10:27 AM
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    So what is the answer to the question OP asked of whether or not it is OK to drive a couple hundred miles on a smaller tire?
    gudujarlson likes this.
  11. Nov 3, 2021 at 10:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    If you just want your 4 high dollar tires on the ground, the spare doesn't need to be the same exact size.
    But it would be good to choose one close to the same diameter, which is easy to do with the tire calculator.
    Then find a great shape used tire that fills the bill, assuming your current spare doesn't already.
  12. Nov 3, 2021 at 10:35 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    No.
  13. Nov 3, 2021 at 10:39 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    So you can deal with it every time you use the bed? Or do you use the bed?
  14. Nov 3, 2021 at 10:46 AM
    CT Yankee
    CT
    If it were me and I was between a rock and a hard place, I'd put the smaller tire on the front and stay out of 4WD.
    Is it really bad for the front axle? I don't have an answer.
  15. Nov 3, 2021 at 10:55 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    UNeven sizes WILL wear & heat the differential
    depends on speed ........distance.........load
    a cheap tyre same size on spare is a viable solution
    be certain to measure tyre size
    numbers on sidewalls dont compare accurateley
  16. Nov 3, 2021 at 10:57 AM
    E.J.
    Josh
    NWA
    The owners manual says the max speed on the spare is 50mph and stresses repeatedly that it's for temporary use. YRMV.
  17. Nov 3, 2021 at 11:12 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I have standard full-size spare...which is actually a 16" wheel as opposed to 17" (265/65R17) on my Sport. I didn't see the actual size of the 16" spare but I would say it measures the same as the 17".
    As far as running a smaller tire (I'm guessing standard full-size that came with the truck) with those 285/65/18s...is no bueno. I would imagine it will affect the alignment + drive train (depending on how many miles is driven on spare) the next time you have a wheel alignment.
    I would make the same decision and stay the night and wait for the matching tire.
    In MY future, when it's time to change the tires, I would upgrade to newer wheels & tires (5 matching) and add high clearance dual swing out for spare and jerry cans.
    That's a BIG chunk of change but at least I can save NOW for a couple of years...if not sooner.
    Ed
  18. Nov 3, 2021 at 11:17 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    Yes and yes
  19. Nov 3, 2021 at 11:27 AM
    DingleTower
    Manitoba
    Pro MT - Lunar Rock
    The stock tire isn't a "temporary" tire though if used with same size stock tires. The warning says if it "is a temporary" tire to not exceed 50mph. It's a full size spare.
    Thats also a CYA due to uncertain bolt torque, no TPMS, etc.
    I would not hesitate to drive on the spare tire at any speed for any amount of time. But I'm an absolute wild man like that.
    This is, of course, if all tires are the same size. So we're a little off topic here.
    Kev250R and E.J.[QUOTED] like this.
  20. Nov 3, 2021 at 11:40 AM
    E.J.
    Josh
    NWA
    Akshully the manual says the steel wheel is marked temporary, IDK what makes it so but there is a sticker on the wheel itself. Agreed that it's probably a CYA. I've got a matching 33" tire on my stock steel spare wheel. I wonder if the temporary designation is because the lug nuts aren't the correct type for steel wheels?
    Kev250R and DingleTower[QUOTED] like this.
