Spare Tire Size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beanster, Oct 22, 2015.
  1. Oct 22, 2015 at 3:39 PM
    Beanster
    Beanster [OP] Active Member
    Jay
    Maryland
    '13 SR5 Tacoma
    I just upgraded from the stock 16" wheels to aftermarket 17" wheels. Do I need to get a 17" spare wheel/tire? I'm just not sure if its ok to drive on two different diameter wheels.
  2. Oct 22, 2015 at 3:52 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    It won't hurt to temporarily drive on the different size spare. A larger size spare may not fit or come really close to the exhaust.
  3. Oct 22, 2015 at 4:07 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    When I switched to size 17's" I had no problem storing the spare underneath.
  4. Oct 22, 2015 at 5:21 PM
    Beanster
    Jay
    Maryland
    '13 SR5 Tacoma
    My second question would then be, where can I find a cheap 17" spare?
  5. Oct 22, 2015 at 5:35 PM
    Tex-Tac
    TEXAS
    Cheap 17" tire/wheel?......keep in mind that you get what you pay for......with that being said check any local tire fix-flat tire shop, they should have a good to not-so-good 17" tire?
    But for starters that's just the tire itself, good luck trying to find a matching size wheel/rim from one of those places-not impossible-but very difficult locating just one to match the 17" tire size!
    How I did it was when I first purchased my wheels and tires from Discount Tire, I went ahead and purchased a spare tire (at the same time) along with the same style rim/wheel as all the other four that I had just replaced from my original OEM wheels/tires.....that solved it for me.
  6. Oct 22, 2015 at 7:05 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The wheel size doesn't matter as much as the outside diameter, if they are close in height you should be ok for short emergencies.
    Chuy likes this.
  7. Oct 22, 2015 at 7:29 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Remember that while driving normally, you essentially have an open differential. You can drive with different overall tire and wheel diameters without issue. It is not ideal to drive with different tire sizes for extended periods of time, but in emergency situations (such as getting a flat, and driving to your house or local tire shop) using your smaller/larger diameter spare will not cause any issues. You may experience pull in one direction due to the difference in overall tire size.
    Now, if you have to drive extended distances (lets say you off road in remote areas) and get a flat, it would benefit you to have a full size spare, or a spare that is the same overall diameter as the rest of your tires, as to not cause excess wear on your differential.
  8. Oct 23, 2015 at 3:29 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    17" wheels are not cheap. Try craigslist or eBay. There are vendors that sell aftermarket spare wheels. I bought a 2nd OEM aluminum spare wheel from eBay ($80) and went to a local used tire shop to buy an used LT tire. I carry the 2nd spare in the bed when I go on extended road trips or go the dez; that way, changing a flat is easier/quicker than the one under the bed.
  9. Oct 23, 2015 at 6:22 AM
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    craigslist
  10. Oct 23, 2015 at 6:47 AM
    SethB
    SethB Well-Known Member
    TDY
    **SOLD** 2009 DCLB 4X4 Auto
    OME Suspension, SPC UCAs, ARB Bumper, Smittybilt Winch, Ext Brakelines, SOS Sliders, 4x Innovation Rear bumper
