Spare Tire Size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Airborne22, Dec 7, 2021.
  1. Dec 7, 2021 at 10:07 AM
    Airborne22
    Airborne22 [OP] It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    Anyone put a 17" wheel in the same stoke spare tire location? Any issues?
  2. Dec 7, 2021 at 10:18 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is all the same.
    The only issue is if you go with a larger diameter tire. I had to bend out the tabs a bit to fit a 32in spare. About the biggest that you can get in there is a 33 without doing more work as it will rub on the diff.
    Airborne22[OP] likes this.
  3. Dec 7, 2021 at 10:21 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    My '06 has stock 17" tires with a matching size spare. The spare is carried between the rear diff and the rear bumper. There is not a lot of extra room but it fits neatly.
    Tires are 265/65-17
  4. Dec 7, 2021 at 10:21 AM
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    I went with 17" wheels and never got a 17" spare. Now that I am putting new tires on, I thought I would take the best one and mount it as a spare. Just need to get a single 17" steel wheel.
  5. Dec 7, 2021 at 10:25 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    The size of the wheel is irrelevant.
    The important factor is that the spare tire is the same diameter as your other tires (or very close).
  6. Dec 7, 2021 at 10:31 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. You have no issues.
    I did flip my spare over so that I have easy access to the valve stem. If you put the stem anywhere toward the front, you will have no worries.
