Spare tire size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nc_oldhead, Oct 1, 2024.
  1. Oct 1, 2024 at 8:32 AM
    nc_oldhead
    nc_oldhead [OP] Member
    Tyler
    2022 SR5 4x4
    Recently got new tires and rims 265/70/17. Of course I got a flat within a month and had to use stock spare on rear. I only drove about 5 miles to the shop to get a replacement. What are the chances I damaged my diff? I’m gonna get a full sized spare now. Is it ok if I just get a cheap 265/75/16 that way I don’t have to get a new spare wheel?
  2. Oct 1, 2024 at 8:37 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Negligible additional wear on your open diffs.
    I've driven on mismatched spares on my Tacoma twice with no issues. First time was 1200 miles (3x 32" + 31" spare). Second time was 200 miles (3x 35" + 32" spare). Unless you plan to be 1000+ miles from civilization, leave the factory spare as-is. When the time comes to replace the spare due to age (6 yrs, 2028), get a matching size then.
  3. Oct 1, 2024 at 8:37 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Zero.
  4. Oct 1, 2024 at 8:40 AM
    Bishop84
    Bishop84 Well-Known Member
    It's a Toyota :) you're good. Basically the diff thought you were on a long gentle turn for 5 miles, no damage done.
    The stories of destruction are from enhanced differentials and transfer cases long term with mismatched tires.
    3JOH22A likes this.
  5. Oct 1, 2024 at 8:41 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No issue with either. Diffs do the work.
    If you happen to need 4WD, that would even be just fine on loose surfaces.
  6. Oct 1, 2024 at 1:24 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    get a used tire that is the same diameter as the 17's.
    no harm but its best to plan ahead for things "before".......if you were far from home you could put spare on the front
  7. Oct 1, 2024 at 2:26 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Absolutely no damage was done to your diff. But don't quote me, I'm just some guy on the internet.
  8. Oct 1, 2024 at 2:33 PM
    jmneill
    SE
    So you say...
  9. Oct 1, 2024 at 8:03 PM
    LFOD
    LFOD Well-Known Member
    2021 SR5 DCSB
    265/70 17 is the stock 4Runners size. Look for a 4Runner spare tire takeoff on marketplace.
    I found a never used spare for $75.
