Spare Tire/Wheel with different offset
Discussion in 'Wheels & Tires' started by TriEsetters, Jun 23, 2024.
  1. Jun 23, 2024 at 8:34 AM
    TriEsetters
    TriEsetters [OP] Member
    2021 SR5 Access Cab
    I was going to get a set of the stock 5 spoke steel wheels for winter tires on a 2021 SR5.
    My understanding is that there is a 5mm difference in the offset of the stock steel vs the oem alloys.
    I assume the spare wheel has the same offset as the oem. Would there be an issue using the spare with the stock wheels in either 2 or 4wd?
  2. Jun 24, 2024 at 8:34 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    No issue. If you're planning a 5 tire rotation then you should make sure all 5 are the same spec. But, if you're just using that 5th wheel as a temporary/emergency spare then a slightly different spec isn't a concern at all.
  3. Jun 24, 2024 at 9:19 AM
    TriEsetters
    2021 SR5 Access Cab
    Thanks for this. Yes, the spare would be only used as just that, temporarily.
    I just wanted to be sure my spare was OK to use (in 2 and 4wd) with these steel 42601AD041 wheels.
    These steel wheels are coming off a SR and I thought maybe the spare specs were specific to the different trims.
  4. Jun 24, 2024 at 9:49 AM
    clenkeit
    Colin
    Lakewood, CA
    In your instance, wheel offset is not as important as tire size (specifically, overall tire diameter.)
  5. Jun 24, 2024 at 11:28 AM
    TriEsetters
    2021 SR5 Access Cab
    Right on, I've no plans to change the winter tire size, sticking to the original/spare tire sizing.
    Thanks again
