Spare Tire with 285s
Discussion in 'Wheels & Tires' started by jmed99, Apr 16, 2010.
  1. Apr 16, 2010 at 10:30 AM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    What do I do for a spare tire if I go with the KM2 285/70/17? Obviously the stock spare will not work. I would rather not buy a 5th KM2 to use as a spare.
    What are my options here?
    Thanks! :D
  2. Apr 16, 2010 at 10:32 AM
    fhlashsf
    fhlashsf Well-Known Member
    Curt
    Danville, CA
    '10 Off Road Double Cab 4x4
    Weathertechs, Avid bolt-on sliders and light bar, 17" ATX Thug wheels, BF Goodrich AT 285/70/17 tires, Icom 2820 Dstar radio, OME 3" lift, color matched rear bumper and Grillecraft grille, Wet Okole seat covers, ARM bed extender, black badges, Sockmonkey decals, HID headlight and foglights, TRD cat back exhaust, TRD CAI, URD MAF calibrator, Kenwood 6960 HU, Image Dynamic front and back speakers, ARC Audio Sub in Mr. Marv custom sub box and amp rack, Tuffy security box for bed.
    Good question....would a 285 fit in the spare tire compartment?
  3. Apr 16, 2010 at 10:33 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    A 285 will fit, you just have to grind off the tabs that are on the frame. A 2 minute job with a grinder, paint. I put some radiator hose on the frame to prevent rubbing rash. I'm running a full size 285/70/17 MT spare.
  4. Apr 16, 2010 at 10:34 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    a spare is a spare man. unless you plan on driving hundreds of miles on it I wouldnt worry about it. but if you do want to fit a TALLER tire under there, there are some tabs that can be cut off to allow a bigger one.
  5. Apr 16, 2010 at 10:49 AM
    jmed99
    SC
    So buy a used 285 and put it under there....will the 285 fit on the spare rim? Or do I need to buy a cheap 285 used with a el'cheapo rim?
    Thanks for the help!
  6. Apr 16, 2010 at 10:50 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    do you really need that wide of a tire for a spare? or do you mean a 33" TALL tire?
  7. Apr 16, 2010 at 10:54 AM
    jmed99
    SC
    Oh....yeah I just mean a 33" tire
  8. Apr 16, 2010 at 10:55 AM
    jmed99
    SC
    What are you recommendations for a 33" tire...not necessarily a 285/70/17?
    Thanks for answering my dumb questions!
  9. Apr 16, 2010 at 10:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    alright den, yea 285 is the width. for the spare you would want something like a 265 to 275 X 70
    The second number is how tall the tire will be
  10. Apr 16, 2010 at 10:57 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    275/70/17 would be fine.
  11. Apr 16, 2010 at 11:00 AM
    jmed99
    SC
    I have the TRD OR rims so they are 16". Would a 275/17/16 work on the spare rim?
  12. Apr 16, 2010 at 11:09 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    275/70/16 or 270/70/16 would be fine for a spare, I have 33"s and Im still running the stock spare, Never used it and If I had to i would only be to get me to the tire shop to get a new tire.
  13. Apr 16, 2010 at 11:21 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Depends on what you want it for?
    If your out of town on a trip on a Sunday..good luck with finding a 33 to get home on.
    If you live in Bumblefug Egypt...good luck.
    If your out on the trail...good luck.
    If your towing or have a full load (ATV) in the back...good luck.
    IMHO better to have a full size, good condition spare that can get you out of jam. I've been put in that situation before with a crappy undersized spare and learned my lesson :annoyed:
    microsnook likes this.
  14. Apr 16, 2010 at 11:25 AM
    jmed99
    SC
    Oh so that's ok to do? Worse case you get a flat while out of town and your on an interstate. Would it be safe to get back on the interstate until you find a tire shop that is open...which may be a long ways down the road if it's in the middle of the night, ya know?
    Knowing my luck and murphy's rule, that's when I would get a flat.
  15. Apr 16, 2010 at 11:28 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I see cars running on those lame ass little bity donut spares all the time. I doubt it our stock spare would hurt anything but if your concerned about it, it wouldnt hurt to get a full size, to have that piece of mind.
  16. Apr 16, 2010 at 11:32 AM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    you can fit a 285 on a stock rim. If you mount it on the front you'll get a little rub on the back your all good. I've got a 265/75/16 mounted on my spare rim. I've driven home from a camping trip (150 miles) loaded up with gear and didn't have any problems. The tire was actually pretty close in overall height to the 285's I'm running. If you tow a lot I'd get a matching size spare, b/c your truck will definately react a differently with a smaller tire on one corner.
  17. Apr 16, 2010 at 11:39 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I have full size 285/70/16 spare.
    On anothe truck with posi track I burned up the clutches in the rear end running a slightly smaller tire. cost me a lot more to fix that than a full size spare.
    but i don't have posi track on my taco so, your call
  18. Apr 16, 2010 at 12:22 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    285 has nothing to do with the height.
    http://lmgtfy.com/?q=how+to+read+tire+sizes
  19. Apr 16, 2010 at 12:43 PM
    djs05tacoma
    Martinez, CA
    3" OME Lift, 285's
    Not sayint it does.
    Just saying my 265/75/16 in almost new condition was about the same height as my 285/75/16 in almost worn out condition. within 1/2" or so. The tires being so close in height minimized the akwardness or lean that I would have had if the tire was much smaller in overall diameter
  20. Apr 16, 2010 at 12:47 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    ok, that makes more sense now, it sounded like you were saying that the first number was your height and that a 285 and a 265 were just as tall as one another.
    a 285 and a 265 can very well be the same height, it's the numbers after that which will make up how tall it is
