Spare Tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyoda Tacoma, May 15, 2012.
  1. May 15, 2012 at 2:20 PM
    Toyoda Tacoma
    Toyoda Tacoma [OP] Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    What does everyone have for a spare tire if you upgraded your size? Did you buy 5 new tires or did you buy 1 used one the same size and did not care about what kind of tread was on it?
  2. May 15, 2012 at 2:22 PM
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
    left the stock one up under there, if you really need it one stock tire and 3 35's will get you down the road better than a flat lol
  3. May 15, 2012 at 3:17 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    thats a fact lol
  4. May 15, 2012 at 4:03 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    x2
  5. May 15, 2012 at 4:06 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Yup... Itd just be like one of those donut spares on a car
  6. May 15, 2012 at 4:17 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Kept my 16in stocker. What he said^
  7. May 15, 2012 at 4:22 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    Bought a used 16 inch rim (stock was a 15???) and put one of the old tires on it.
  8. May 15, 2012 at 4:29 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Full size spare. When you are wheelin in the middle of nowhere and you need 4wd the stock spare ain't gonna do much good.
  9. May 15, 2012 at 5:50 PM
    Toyoda Tacoma
    I thought I read somewhere having one small tire and one larger tire on a 4x4 is not good for the gears.
  10. May 15, 2012 at 8:23 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  11. May 15, 2012 at 9:05 PM
    Ernesto4
    Ernesto4 Well-Known Member
    North Hollywood
    15 Tacoma access cab 5 lug SR5
    does anyone know where I can get the tool to remove the spare tire. I just bought my taco and it didn't.come with it. not including the dealership
  12. May 15, 2012 at 9:15 PM
    cgs2k2
    cgs2k2 old man
    try ebay.
  13. May 16, 2012 at 6:17 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    When I bought my 17" BBS wheels I purchased a steel 17" Toyota wheel from Ebay and bought another same size 17" tire. Running different size tires on the same axle isn't good for the gears.
  14. May 16, 2012 at 7:11 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    If you have your locker on, that's true. If you have an open diff (or locker turned off) then it isn't any different than driving around a corner from the gears perspective.
  15. May 16, 2012 at 8:17 AM
    medic2230
    Murph
    Bama! Roll Tide
    Kept the stocker with 33's.
