Spare tire
Discussion in 'Texas' started by Jalockett, Apr 6, 2017.
  1. Apr 6, 2017 at 12:37 PM
    Jalockett
    Jalockett [OP] Well-Known Member
    Joshua
    Houston, TX
    '11 Prerunner V6 Sport
    Fire Department based modifications
    Just got a new spare tire, think it will work?
    JoeDLS, Spare Parts, Tex-Tac and 3 others like this.
  2. Apr 6, 2017 at 1:54 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Youll probably need some wheel spacers to clear the uca's but other than that, should fit just fine :thumbsup:
    If you dont mind me asking, what happened to your tacos quarter panel/cab?:eek: Btw i dig the barcelona red! One of my favorite colors they offered..
    StricklandJN and Jalockett[OP] like this.
  3. Apr 6, 2017 at 2:03 PM
    Jalockett
    Joshua
    Houston, TX
    I went off roading in the middle of the night into a pole. :anonymous: And then someone rear ended me on the other side. :annoyed:
    So I bought to gray ones and now just need a paint job.
  4. Apr 6, 2017 at 2:06 PM
    BassAckwards
    Lol well at least only half of it was your fault.. you wont even be able to tell once its painted up! Did you do the body work yourself?
  5. Apr 6, 2017 at 2:12 PM
    Jalockett
    Joshua
    Houston, TX
    No the primer and stuff was done at the college I was at as a class project. It took 3 months but it came out pretty good. The door was bondo but the rear quarter panel on the cab was a part bought from Toyota.
  6. May 13, 2017 at 8:23 AM
    tony2018
    tony2018 Well-Known Member
    Off topic, how hard was it to replace the side of the bed?
  7. May 13, 2017 at 8:36 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Will it fit with no lift?
    StricklandJN and Spare Parts like this.
  8. May 13, 2017 at 8:39 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Easy. The fender just un bolts
    Jalockett[OP] likes this.
  9. May 14, 2017 at 7:48 AM
    Jalockett
    Joshua
    Houston, TX
    Is there a topic to this thread? To answer your question, it is pretty simple. There are a lot of 10mm bolts if I remember correctly. Where the fuel neck and fuel door are, you will need to drill out the rivets. I also suggest removing the bed to do this job, so you'll need a T-55 socket head and the ability to disconnect quick disconnects. If I had thought about it, I would have done a full write up.
    Ha, I'd have to put the second one on my roof rack.
    J Bumble likes this.
  10. May 14, 2017 at 7:50 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Fixes the taco lean
  11. May 14, 2017 at 7:55 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Just a little trimming and you'll be good :thumbsup:
