Spare Tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lawrenccar1, Sep 9, 2017.
  1. Sep 9, 2017 at 8:36 AM
    lawrenccar1
    lawrenccar1 [OP] Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    I dropped my spare tire for the first time while doing the rear breather mod. When i return the spare (valve stem down) i have slight movement if i try to rock it. Is that normal or maybe it is not sitting exactly right in the bracket ? Thanks
  2. Sep 9, 2017 at 8:40 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Sub'd.... noticed mine does the same thing, would be nice if it would tighten up more
  3. Sep 9, 2017 at 8:41 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    There should be no movement. Otherwise there will be wear on the tire or rim in normal driving.
  4. Sep 9, 2017 at 8:52 AM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    Crank on it a bit more to snug it up.
    TexasWhiteIce and inwood customs like this.
  5. Sep 9, 2017 at 9:02 AM
    Pigpen
    Dan
    Northwest Montana
    crank on it
    I keep mine valve stem up and it's snug. With a 33.5" tire up there, it takes a little effort to make it fit. Cranking good and snug is a must.
    excorcist and inwood customs like this.
  6. Sep 9, 2017 at 9:10 AM
    vtdog
    vtdog Well-Known Member
    NH
    I found that with the valve down I had a hard time getting the tire to hold fast. I bought a valve extension similar to this on ebay: http://www.ebay.com/itm/12-300mm-Fl...ash=item5695e9c634:g:xggAAOSw2gxYxiiK&vxp=mtr. The extension allows for valve up storage with the extension end snaked down through the hub hole.
    I have had it on for almost 7 years without issue. Plus it makes it very easy to check PSI without having to drop tire.
    PzTank and excorcist like this.
  7. Sep 9, 2017 at 9:28 AM
    lawrenccar1
    funny, it had wear on it when i dropped it down (first time). I am going to put valve up and try it again.
  8. Sep 9, 2017 at 9:38 AM
    lawrenccar1
    After a recheck (after driving around town) it is now tight. Must of settled in place. :)
  9. Sep 9, 2017 at 11:16 AM
    excorcist
    Reno, NV
    Hmm mine is mounted with the valve stem down too, Ill have to try flipping it around and see if that fixes it... I have tried cranking on it to no avail... It is a 33'' tire too so would like it to be snug.
  10. Sep 9, 2017 at 11:47 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I think i cut part of 1 of the arms off yrs ago when i went to 265/75/16 as it was not flush. I wanna say it was a part that jutted outwards so there was no fear of tire damage.
    Make any sense?
  11. Sep 9, 2017 at 11:49 AM
    excorcist
    Reno, NV
    Yea....I just hammered the little tabs back to fit the 33''.... my tire fits in the spot well, just not snugging up with the cable, it runs out of adjustment before it is fully snug.
  12. Sep 9, 2017 at 11:53 AM
    inwood customs
    Dave
    Bummer
    excorcist[QUOTED] likes this.
