Spare tire
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jason TRD OR, May 6, 2018.
  1. May 6, 2018 at 8:54 AM
    Jason TRD OR
    Jason TRD OR [OP] SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Hey guys I have a method nv and wanna put it under the truck as a spare. Will it work?
  2. May 6, 2018 at 8:59 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Probably depends on the tire size. You'll have to remove the center cap obviously. I bet it'll work. It's going to be dirty as all get out if you don't remove to clean every once in a while. A lot of guys rotate them into the rotation also.
  3. May 6, 2018 at 9:01 AM
    Jason TRD OR
    Cool thanks just wanted to make sure because just want a matching spare wheel if I ever need to use it.
  4. May 6, 2018 at 9:02 AM
    toyotatacomaTRD
    I have no experience, but want to do it eventually as well. Hopefully someone who has will chime in with tips.
  5. May 6, 2018 at 10:15 AM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    So what size tire are you trying to fit under there? Pretty sure a 33" is the largest you can fit.
    Do a search and there is plenty of threads on this. You gonna have to hammer in those fork looking hangers underneath. Depending on exact measurements as some are 32.8" and some are more than 33" it may rub your rear diff and/or exhaust.
  6. May 6, 2018 at 10:21 AM
    tcjacado
    tcjacado Well-Known Member
    It can fit a 33 with some modification of the tabs. They need to be hammered or cut off. The tire may still rub on the diff/pumpkin. Use a ratchet strap and secure to the bumper to pull it away from the diff.
    remgu2000 likes this.
  7. May 6, 2018 at 6:40 PM
    Jason TRD OR
    Just a 32"
  8. May 6, 2018 at 6:43 PM
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    It'll easily fit.
  9. May 6, 2018 at 6:52 PM
    toyotatacomaTRD
    My 2nd gen was a year old when I got it. The guy before swapped out wheels and put a same size spare under. It was turned so you could reach the valve stem from underneath. Really easy to keep the pressure current. Wondering if that's something we can do with the stock spare.
  10. May 7, 2018 at 4:36 PM
    MGMTaco17
    MGMTaco17 Well-Known Member
    Orange County, CA
    2017 Tacoma DCSB TRD Sport
    2017 DCSB TRD Sport. TRD Pro Grille. Morimoto Elite 35W HID Headlights. Morimoto XB LED Fog Lights. Clazzio All Black Leather Seat Covers. 32" LED Light Bar Bumper Stealth Mount. BHLM. Raptor Light Kit. Leer 100R. Bilstein 6112/5100 set at 3rd notch. LT275/70-17 C-Load Hercules Terra Trac AT2. Bora .750" Wheel Spacers.
    No, it wont fit... Mount it on the roof
  11. May 7, 2018 at 4:41 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    32" will fit 33" will fit with mods.
    I had to remove the chain and move it about an inch back towards the tailgate. And hammer the driver side tab away.
    I was hitting diff and exhaust. Now I'm clear but very close .
    Rim wise I don't see why it wouldn't as long as you remove centre cap.
