Spare tire
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cooldad, Sep 3, 2024.
  1. Sep 3, 2024 at 5:25 PM
    cooldad
    cooldad [OP] Well-Known Member
    JimBob
    2021 red TRD Sport
    2021 TRD Sport
    Got a short hose extension and tube (Amazon) to allow me to check spare tire inflation without removing spare. < $10
    Jakerou likes this.
  2. Sep 3, 2024 at 5:32 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Is this a question? Or did you find one. If so, link?
    BlackTRD4Me likes this.
  3. Sep 3, 2024 at 5:40 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I’m thinking it’s a question. Maybe. Not sure though lol
    71tattooguy likes this.
  4. Sep 3, 2024 at 5:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    I use one in the RAV
    On the truck I just flipped the tire over so it's stem down
  5. Sep 3, 2024 at 8:00 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    get a 12v air pump and you might not ever need to use a spare and if you do you got an air pump with you
    3JOH22A likes this.
  6. Sep 4, 2024 at 6:46 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Various kits available on Amz. Can get them with 90-deg or 135-deg elbows too, e.g. https://www.amazon.com/Z-oneMart-Valve-Extension-Compatible-Motorcycle/dp/B0BZPXYZPV/
    If you go off road, better to deflate the spare completely for maximum puncture resistance. Carry a pump full-time. This well-proven small pump is on sale, fits in access cab under-seat bin: https://www.amazon.com/Viair-00088-88P-Portable-Compressor/dp/B005ASY23I/
    joeyv141 likes this.
  7. Sep 4, 2024 at 7:17 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Is this something that you install and leave on the valve? What's the likelihood the extension will leak? A worry for sure. It doesn't take much effort to drop the wheel so I can't see the value personally. Lowering the wheel occasionally also allows you to have the comfort that the mechanism is still functional.
    Chew and Jakerou like this.
  8. Sep 4, 2024 at 7:42 AM
    TacBroma
    TacBroma Well-Known Member
    2020 Tacoma TRD OR
    3JOH22A[QUOTED] likes this.
  9. Sep 4, 2024 at 7:49 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I would flip the spare over so you can access the valve stem easily. This post does give me the idea to put a hose on my civic spare tire since has to be valve stem facing down so I can check pressure with some regularity instead of honestly maybe twice a year.
    For the inflator, the vlair that is posted in a previous post is a damn good inflator.
    RIX TUX likes this.
  10. Sep 4, 2024 at 12:05 PM
    RIX TUX
    exactly.......some cheesy Amazon product that will triple the chances of leaking
    Jakerou likes this.
  11. Sep 4, 2024 at 12:12 PM
    cooldad
    JimBob
    2021 red TRD Sport
    This isn't a question. The short hose and tube are available at Amazon. Mine has valves, so all you have to do is screw it on.
  12. Sep 4, 2024 at 12:37 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    The mounting of the spare underneath the truck is the worst possible location. Not only is it "out of sight, out of mind," it's difficult to remove when needed, and it's exposed to road hazards. I keep mine in the bed of the truck. Easily accessible, and easy to check for condition, including the air pressure.
  13. Sep 4, 2024 at 12:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    No worries. Ran one for years on my 04 Highlander, as well as in the trunk of several vehicles, including the current 14 RAV, that only allow securing the wheel when the stem faces the floor.
    In fact , I've moved the same extension across vehicles so its at least between 15 and 20 years old now
  14. Sep 4, 2024 at 1:14 PM
    RIX TUX
    good idea.....i got another spare on FB for 40 bucks, throw it in the back for trips or going off road, also have air pump and tire plugs and an impact wrench.....but changing the spare is the last resort
    BillF1564 likes this.
  15. Sep 5, 2024 at 3:39 AM
    999 Well-Known Member
    Texas
    I partially agree. But in Houston, the UV from the Sun exposure, and potential theft are cons to the bed unless you have a bed cover.
  16. Sep 5, 2024 at 5:39 AM
    NC Gazzer
    Durham, NC
    I'm glad your system works for you. Everyone's needs are different, though. For me there is no way I could store mine in the bed, which I use frequently to transport stuff. In this regard, under the bed is the perfect location for me. I don't find it difficult to remove - the hardest part is digging out the cranking tools. I have a standard routine of checking all pressures monthly, so it's never forgotten. It does get a bit muddy/gritty but in close to 30 years under the truck, I've never had a spare tire damaged by road hazards. I have an occasional worry that the cable will break and I'll lose the tire so I do find the monthly check of the cable mechanism comforting. I think the current chain system is probably more robust.
    Clearwater Bill and Jesse H like this.
  17. Sep 5, 2024 at 5:42 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Agreed. A spare in the bed would use up much of this already small bed.
  18. Sep 5, 2024 at 6:27 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    In Wyo my frequent drives in mines and on oil field roads combined to cure me from using the the "under the bed" set-up. Not too bad during the warm month or two - but when the mud and gunk gets combined with ice - try changing a tire .......... Seemed to work best for me when standing upright directly behind the cab. Arizona has spoiled me - but I did flip the thing over to put the valve side down.
    NC Gazzer likes this.
