Spare tire
Discussion in 'Wheels & Tires' started by StevieD21, May 2, 2025.
  1. May 2, 2025 at 12:36 PM
    StevieD21
    StevieD21 [OP] Active Member
    NorCal
    2016 TRD Off Road
    N-fab nerf bars Method Roost Wheels BF Goodrich KO2
    Was thinking of running 295/70r17 ko3 which measures to 33.3x11.8. Was wondering if running the KO2 spare of 34x10.5 which measures to 33.5x10.5 is okay.
  2. May 2, 2025 at 12:41 PM
    TacoDell60
    TacoDell60 Well-Known Member
    If you only run that spare in the front while in 2wd you'll be okay.
    If ever you need to run it in 4x4 for an extended period of time it will not be optimal and may cause weird binding
  3. May 2, 2025 at 12:46 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    With that small of difference I would not be concerned running it even on the rear. The actual size however may be more than .2.
  4. May 2, 2025 at 5:11 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    You're fine. Only if you had a mechanical (clutch-type) limited-slip differential would this be an issue (which your 2016 did not come with).
    Same for the 4x4, it'll be fine as long as you are on dirt (which normally would be the case anyway).
