Spare wheel chain
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RM61188, Nov 22, 2015.
  1. Nov 23, 2015 at 5:48 AM
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    It's the slack in the chain when the spare is up that hangs down. Maybe I'm anal but I also put a lock on the chain, if/when the time comes to lower the spare I'll get a little dirty, no big deal.
    CusterFan likes this.
  2. Nov 23, 2015 at 6:18 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    how much time do you spend under your truck looking at the chain? The only time you see it is when you look under there. petty shit
    Lawfarin likes this.
  3. Nov 23, 2015 at 7:15 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Everybody is different.
  4. Nov 23, 2015 at 7:29 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Powder coat and better steel.
    If I had my way, Toyota would have been boxing them, then galvanizing the frames for the past 25 years.
  5. Nov 23, 2015 at 7:32 AM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Mine hangs like that on my second gen.
  6. Nov 23, 2015 at 5:36 PM
    AZInferno
    AZInferno Well-Known Member
    2016 TRD Sport Inferno
    I'm just happy the truck has a spare, my wifes car is a 2013 Hyundai Elantra and they do not come with spare tires- what you get is a very small compressor and a can of fix a flat, trouble is we were out in the middle of nowhere in 113 degree heat when I drove over a glass bottle on a dirt road I didn't see, which sliced my left rear tire with a 3 inch cut, no can of fix a flat is going to do a damn thing about that. Called for a tow and 2 hours later had the car on a flatbed heading home....I mean seriously, no spare tire? Bozos. Imagine my surprise when I lifted the spare tire cover and saw it was empty.
  7. Nov 23, 2015 at 5:50 PM
    UAL777jet
    UAL777jet Well-Known Member
    Bill
    Norwalk, IA
    2019 Tacoma TRD Pro Voodoo Blue
    TRD Performance Air Intake
    I am torn, flip the wheel to collect mud and debris or leave it and not be able to check air pressure since it doesn't have tpms? Is there such a thing as a plastic cover sold aftermarket?
  8. Nov 23, 2015 at 6:17 PM
    UAL777jet
    Bill
    Norwalk, IA
    Never seen a valve stem extension. My first truck, but I bought my son a truck in high school and the last 6 years I tried both ways and in the inverted OEM way, the wheel collected gravel road and hardened like cement. However, I left it to check the tire pressure more easily.
  9. Nov 24, 2015 at 7:56 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    My 15 has a chain too, being paranoid about theft I wrapped it up through the tire and put a padlock on it. 2 birds one stone. I sprayed some wd40 in it and taped the bottom but now I am concerned the lock may be jammed up when I need my tire. Good idea in theory though.
  10. Nov 24, 2015 at 8:07 AM
    JeffreyB
    Jeff
    I have heard of it but not nearly as common as on jeeps. Probably ranks less common than tailgate theft. I don't think it happens around here much (although I do see a lot of jeeps without a spare) but if i go to Denver or California you'll get everything stolen that isn't locked down in certain places.
    I had 4 KC lights stolen off my jeep locally a couple years back and I have been paranoid about people stealing crap off my vehicles ever since.
  11. Jun 17, 2016 at 4:26 PM
    jasontylers
    jasontylers Well-Known Member
    JT
    2016 Tacoma TRD Off Road
    None.
    I'm 99% sure my spare tire was stolen. It must have been the past few days because you can see it just walking next to the truck and it's suddenly not there. I'm in Denver. Why do people do that!?
  12. Jun 17, 2016 at 4:36 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    I guess on the scale of petty thefts, it's pretty minor. At least no one was killed or mugged, and nothing was broken. I had a previous truck broken into and some spare change for parking meters stolen. The problem was that they broke the side window to gain access. I wished that I had left it unlocked!
  13. Jun 17, 2016 at 4:38 PM
    jasontylers
    JT
    None.
    That's crazy. At least they didn't steal any valuables from under my unlocked tonneau cover.
    oldtoyotaguy[QUOTED] likes this.
  14. Jun 18, 2016 at 9:34 AM
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    You should be lowering the tire down at least once a year for a number of reasons. Check air pressure, check wheel for rust and paint if needed, grease the chain and crank components. The chain hangs down a few inches below the bumper, it clearly visible from the back of the truck without even looking for it. Petty you say? I think not, it looks like crap. Hobby grade thin zip tie can be broken with a good yank, problem solved.
  15. Jun 18, 2016 at 9:47 AM
    #35
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Toyota did use a cable for the 2005-2011 Tacoma (one of the few trucks they used the cable on) and switched to the chain for 2012. I don't know if it was related to the recalls for the spare tire cables that affected so many Sienna models or not, but it seems possible. The 2016 continued using the same spare tire chain as the 2012-2015.
    Jeff
  16. Jun 18, 2016 at 12:28 PM
    #36
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    My first 4X4 Toyota pickup was a HiLux in 1980 and it used the same system as my current 2015. My second HiLux was used and the spare was seized. I tried everything to save it but in the end I cut it off and learned how important maintenance is for system like this. I hardly ever stow the tire under there but is convenient when the box is being used for other stuff. Where I live, in a central Ontario snow belt, 4 months of the year you wouldn't want to have to crawl under there if you ever had a flat tire!!
  17. Jun 18, 2016 at 5:16 PM
    #37
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I'm with you Peter... Mine is chained and locked in the box.... Under the Tonneau, so mine is available when needed and will be clean.
    It's no fun getting it out from under the bed.... My chain is zip-tied up tightly and out of the way of branches, etc...
    oldtoyotaguy likes this.
  18. Jun 18, 2016 at 5:19 PM
    #38
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Yep! A handful of zip ties to squeeze every ounce of movement out of the chain and this, a 285/75R16 don't fit under without cutting anyhow.
  19. Jun 19, 2016 at 6:49 AM
    #39
    2016 Tacoma SR
    HOCO Maryland
    Will running a stock size spare with a 285/75 on the other side of the same axle harm anything? I could see it causing the rear diff to bind if you've got a posi rear (not sure if I do or not) but I don't believe it will harm anything up front as long as 4wd is not in use. What do you guys think?
    RM61188[OP] likes this.
  20. Jun 19, 2016 at 10:25 AM
    #40
    cbreze
    cbreze Well-Known Member
    Jim
    Bend, Oregon
    '12 T4R, '74 LC, '88,'98 04' pickups.
    On my 88, 98 and 04 I just tucked the chain in on top of the tire. Never had any problems.
