Spark Knock, Code p0300, Compression difference of 100psi, HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by SmkyMtnFly, Dec 17, 2014.
  1. Dec 17, 2014 at 1:19 PM
    SmkyMtnFly
    SmkyMtnFly [OP] New Member
    Knoxville, TN
    02 4x4 TRD S/C
    What's up guys. I'll get to the point. 02 tacoma TRD S/C 216,xxx. About a month ago i noticed i had a "dead spot" when i was on the highway going up hills, around 70mph. The issue kept getting a more noticeable. The "dead spot" was now really noticeable when accelerating in 2nd and 3rd etc. It felt like a lack of fuel when under load. Changed fuel filter and pump, which were both original parts. No better, no worse. Check engine light comes on one day for o2 sensor and knock sensor. Changed both o2 sensors. Gas mileage got better still had what i will now call a miss/ misfire feeling when under load. Pretty noticeable now when i get in the throttle but after say 4k RPM i don't have an issue and the truck runs good. Decided it would be a good idea to change the plugs/ wires/ coil packs, all parts taken off were original. Start the truck and its starts fine like always and idles good like always, purrs like a kitten. I drive it and it feels good until i put it under load but now which the new plugs, wires, and packs the "dead spot, jerky, misfiring thing" is still there but the noise is SIGNIFICANTLY louder, I'm guessing due to the plugs and such. I am in the process of changing the knocks sensors and wiring harness. I did a compression test earlier out of curiosity: #1 cyl 197 #2 200 #3 140 #4 120 #5 195 #6 155 Looking for guidance on what these numbers mean before i go any further. I'M NO MECHANIC so any help would be appreciated.
  2. Dec 17, 2014 at 1:57 PM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    I'm no Mechanic either...but
    Book Says.
    178 PSI or more
    Minimum 127 PSI
    14 PSI or less, Difference between Cylinders.
    If your readings are accurate you have a problem.
    Cracked head or leaking head gasket, Worn rings maybe.
    Are you seeing any white smoke out of the tailpipe. Any unusual consumption
    of coolant?
  3. Dec 17, 2014 at 2:14 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Piston rings or worn valve seats. Worn rings would cause high carbon build on the plugs. If the plugs look to be to ok.......it MAY be the worn valve seats.
  4. Dec 17, 2014 at 5:43 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    don't forget the well known crack in the #3 cylinder area. still hold 175 compression but did a leak down test, air came out of the tail pipe. :mad:
  5. Dec 17, 2014 at 6:02 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    squirt some oil in one cylinder and see if you get higher compression readings, if its just a little higher its the valves, if its a lot higher its the rings. do each cylinder one at a time. if you put oil in all of them the oil may get on the valves by the time you get to the next cylinder.
    when you see three out of 6 off like that and one being on the opposite head, its more common its a valve sealing issue going on.
    if you are lucky they just need adjusting but I think you might need to have the heads pulled and the valves redone. not all that bad really.
  6. Dec 17, 2014 at 6:12 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Pretty sure worn rings wouldn't be the issue but there again you seem to have quite a discrepancy in your numbers, did you take out all plugs before doing test ?? I'd run another test with a diff. comp. gauge just to be sure its not a bad read from defective tester..can't hurt & doesn't cost a dime
  7. Dec 17, 2014 at 9:36 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    That dead spot could be part of a bad tune if you have the 7th injector kit. If you retard the timing too much it will cut acceleration. If you don't have the 7th, you may have pinged hard and melted a crater in the pistons. It happens.
  8. Dec 18, 2014 at 6:35 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    You did pull all of the plugs to do the compression test right? You said you are no mechanic so im just checking the basics first.
  9. Dec 18, 2014 at 7:13 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If the compression is off that much you have a problem and a knock sensor ain't going to fix it. The sensor is probably doing it's job is has a code because it's still knocking despite the timing retard. The low numbers are on different sides so likely as not it's no head gasket. Bottom line it need to come apart. By the way the knock sensor is under the intake manifold.
  10. Dec 18, 2014 at 10:25 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    It's a pain in the ass to get to the knock sensors. I need to replace my sensor harness sometime.
  11. Dec 18, 2014 at 12:11 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Original pump....was the pump ever upgraded for more fuel since it's s/c?
  12. Dec 18, 2014 at 7:17 PM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    Do a wet test. If the numbers don't change much, for instance if they stay within 20 psi of each other then it isn't the rings. If that's the case, move on to do a cylinder leak test. That way you can pinpoint to a certain degree where the leak is. It will be in any of three areas.. Intake; exhaust or the actual cylinder head (gaskets). You'll here or feel the air coming out.
