Spark Knock randomly comes and goes. If you want a challenge, please read.
Discussion in '1st Gen. Tacomas (1995-2004)' started by QuickSilver, Dec 21, 2011.
  1. Dec 21, 2011 at 8:46 AM
    QuickSilver
    QuickSilver [OP] Member
    North Carolina
    01 Tacoma TRD 4x4 SR5 3.4L Xtra Cab
    My 01 3.4L Manual Trans 4x4 tacoma will spark knock under acceleration at random times. By random I mean, one red light it does it, another red light it won't. I've changed the spark plugs, wires, MAF sensor, air filter, fuel filter, and I have cleaned and applied electronic grease to all of the electronic plugs that I can get to. The CEL is not on. I live in an emissions inspection county, so it has to pass the test where it is hooked up to a computer, and it passes without question. The truck also distinctly runs and accelerates smoother when it doesn't spark knock. It can't be fuel, because it does it so randomly. Help.
  2. Dec 21, 2011 at 8:51 AM
    MNTX
    MNTX Member
    Minnesota/Texas
    2002 Tacoma 4X4
    BFG All Terrain TA
    How many miles are on it?
  3. Dec 21, 2011 at 8:56 AM
    QuickSilver
    North Carolina
    It has 150,00 miles. Keep in mind, when it doeen't act-up it absolutely runs like a champion, very strong and smooth.
  4. Dec 21, 2011 at 9:11 AM
    jvallin
    jvallin Well-Known Member
    joey
    turlock CA
    01 Dcab SR5 4x4
    K&N intake, Magnaflow, HID conversion, 265/75/16 MT, PIAA driving lights, Optima red top, billstein 5100's @ 2.5 and pro comp 2" AAL.
    check your pcv valve and all vacuum lines. if you have a broken vacuum line it could cause this problem, I have also heard that a clogged pcv valve can cause pinging. Take the valve out of the truck and shake it, if it doesn't make a rattle or clunk sound inside of it then replace it. As they are only about 5 bucks if you haven't replaced it in a while you might want to just do it anyway.
  5. Dec 21, 2011 at 9:12 AM
    jvallin
    joey
    turlock CA
    01 Dcab SR5 4x4
    also check the gasket around the maf sensor. It could be broken or gone and allowing air to enter the intake un-metered.
  6. Dec 21, 2011 at 9:36 AM
    QuickSilver
    North Carolina
    I'll check the EGR valve, sounds like a logical solution. Recently installed the MAF sensor, gasket looks good.
  7. Dec 21, 2011 at 9:45 AM
    jvallin
    joey
    turlock CA
    01 Dcab SR5 4x4
    I dont think our trucks had an egr at least I know that my 01 3.4 does not. What I was refering to is the pcv valve which looks like a plastic elbow coming out of the passenger side valve cover. it will also have a vacuum line running from it to the underside of the tb.
  8. Dec 21, 2011 at 9:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    Correct, no EGR on the 3.4 L.
  9. Dec 21, 2011 at 9:55 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Oh this is a tricky one... Does it sound like a misfire??
  10. Dec 21, 2011 at 10:32 AM
    QuickSilver
    North Carolina
    My bad, was thinking PCV and typed EGR. Replaced the PCV just now and so far it seems to be working. Time will tell though, this problem is a come-and-go problem. Will update after a little more time has passed. Thanks everyone for the help.
  11. Dec 21, 2011 at 10:39 AM
    QuickSilver
    North Carolina
    jr97tacoma
    It doesn't sound like a misfire. It doesn't seem to affect the idle/start or anything that isn't under a load for that matter. Sounds just like an older chevy that is having timing advancement issues.
  12. Dec 21, 2011 at 12:39 PM
    Rozz
    Rozz Well-Known Member
    Sturgis, SD
    '15 TRD Sport
    Stuff
    This is a long shot, but a year after I had a shop do my timing belt/water pump, my truck would randomly act strangely. After about 6 months of changing out most that you have with no improvement, I gave up and took it to another shop. He finally figured out that my crank pulley was coming loose, and that the crank position sensor would randomly retard the timing. I had to buy a new crank pulley, but at least the nose of the crankshaft was ok.
  13. Dec 21, 2011 at 1:02 PM
    QuickSilver
    North Carolina
    That is very interesting. Wouldn't have thought of that. Sounds like a possibility though. Changed my timing belt about two years ago. I have often thought that it could be some kind of timing issue, just didn't know how that could be, with the timing setup that these tacomas have. Especially with my problem coming and going.
  14. Dec 21, 2011 at 1:35 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Sounds like bad ground wire to engine. Find where is connected to and check the wire itself
  15. Dec 21, 2011 at 2:23 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Should not knock wonder if one of the knock sensors is bad I think that engine had one for each bank.
  16. Dec 21, 2011 at 2:42 PM
    QuickSilver
    North Carolina
    I'm not familiar with a knock sensor. Tell me more.
  17. Dec 21, 2011 at 8:08 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    What a knock sensor does it basic listen for a a tapping sound . When it does it gives off a A/C current.
    On the 3.4 there are two. Left bank and right bank. They are under the intake in a valley of the of engine. Yes you have to take the whole middle of the engine to get to it.
    To test the sensor is hook up a volt meter set it to A/c current. Use a 3/8 extender and a hammer. You you tap the extender on the block with the hammer the sensor should send out a A/c current( it will be a very small about of volts.) If it does sensor is good if it does nothing sensor is bad.
  18. Dec 22, 2011 at 6:05 AM
    98tacoma27
    Ben
    Not Beech Creek
  19. Dec 22, 2011 at 8:24 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    What grade of gas are you running?
  20. Dec 23, 2011 at 10:43 AM
    QuickSilver
    North Carolina
    mid grade usually. doesn't seem to change anything when I try a different grade.
