Spark plug anti fouler for Tacoma 02 sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by rll131, Jun 10, 2012.
  1. Jun 10, 2012 at 9:31 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    2000 2.4 liter 4 banger
    Im not sure how the anti fouler trick will work with my Tacoma I pretty sure from the YouTube videos I watched that it will only work with the screw in o2 sensor on my truck it's not screw in it is 2 screws and a gasket and the o2 sensor just drops in . What type of anti fouler will work with our trucks since we don't have screwed in sensors?
  2. Jun 11, 2012 at 6:54 AM
    BamaToy1997
    Bill
    Navarre, FL
    What anti-fouler are you looking at? links? I am curious why you are installing one. A properly running engine won't need such a device. Can you give some background on how this came about?
  3. Jun 11, 2012 at 1:18 PM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    I have the p0420 code I replaced the rear o2 still have a cel so I was going to do the spark plug anti fouler trick to get rid of the cel. Will stacking maybe 4 gaskets do the same trick since tacomas don't have screw in o2 sensors
  4. Jun 11, 2012 at 1:21 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I don't think it will work unless it's a screw in type. I have seen many posts about using the anti-fouler, and I wondered how it could work on a Tacoma.
    I think the URD o2 simulator would work better to fix more issues like exhaust leaks and worn out catalytics. It is $100 though. If you gain 1 mpg from better performance it could pay for itself in a year or less.
  5. Jun 11, 2012 at 1:35 PM
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2013 Tacoma T|X Pro TRD Supercharged 4wd 6MT
    All kinds of badass shit. Click on the link in my signature to see.
    The spark plug anti fouler will not work with the triangle flange type o2 sensors on the Tacomas.
    As stated above, the trick only works on screw in type sensors.
    Your best bet would be an o2 simulator....UNLESS you have access to equipment to properly machine out a spacer for the triangle flange. The key is slowing the reading to sensor. You could theoretically stack gaskets, but those wear out.
    I also own an STi and have the spark plug anti fouler on it working flawlessly on my catless set up since day 1.
  6. Jun 11, 2012 at 4:33 PM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    I might still try stacking gaskets just to see if it works. Will a bad cat ruin the new rear o2 sensor? Any issues a bad cat can cause I'm still getting 25-27 mpg so it's not clogged and still runs great
  7. Jun 11, 2012 at 4:39 PM
    koco
    Bay Area Ca.
    '01 Taco
    I don't think a bad cat will ruin an o2 sensor. The sensors get clogged or just worn out. If you motor is misfiring and kicking out soot, it could clog things up.
  8. Jun 12, 2012 at 4:09 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    Why would my motor be misfiring?
  9. Jun 12, 2012 at 4:17 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    Also could the front o2 sensor be bad causing the p0420 or this that not likely.
  10. Jun 12, 2012 at 5:49 AM
    BamaToy1997
    Bill
    Navarre, FL
    Many different possibilities: Spark plug, injector, coil, coil wire, fuel supply, fuel quality....you get the idea. A lot of stuff could cause a missfire. You can narrow it down using a spark tester and a scan tool.
    No. A code p0420 is a catalytic converter efficiency code. If you have a missfire, that will cause a possible 0420. You may have already damaged your catalytic converter if you have been driving with a CEL and a missfire for a while. No amount of changing out any O2 sensor will correct a p0420. Once you have the missfire condition corrected, and the engine is running properly, then look at if the p0420 comes back. You are wasting time and money on O2 sensors that will NOT fix the problem.
  11. Jun 12, 2012 at 5:56 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Are you using any type of fuel additives?
  12. Jun 12, 2012 at 8:21 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    I'm not having any miss fires truck runs great and still getting 25-27 mpg. Just have the p0420 code and wanted to get rid of it I changed the rear o2 sensor and the code still came back on. Don't hear any exhaust leaks so I'm pretty sure it's the cat.
  13. Jun 12, 2012 at 8:22 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    Don't use any fuel additives
  14. Jun 12, 2012 at 11:55 AM
    BamaToy1997
    Bill
    Navarre, FL
    My apologies. an earlier post of yours made me think you were asking "Why would my engine be missfiring?" My error. And yes, if engine is running good, and all else shows ok, then the P0420 means it is Cat time.
  15. Jun 19, 2012 at 3:44 PM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    So would putting in a o2 sim and gutting the cats work fine or will that also cause problems
