Spark plug bold broke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AvsFanTRD, Aug 23, 2013.
  1. Aug 23, 2013 at 10:16 AM
    AvsFanTRD
    AvsFanTRD [OP] Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    So I was tightening down the final bolt after changing the plugs when the bolt broke. Any ideas how to get the broken piece out and where to get a new bolt?
  2. Aug 23, 2013 at 10:20 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Vice grips and lowes/home depot or dealership. Don't crank them down so tight next time. Check the torque value, I bet it's really low..
  3. Aug 23, 2013 at 10:22 AM
    mr2snob
    mr2snob Member
    Chad
    Cincinnati, Ohio
    13 4x4 SR5 Manual
    Spray penetrating oil all over the bolt and let it sit. Get a good set of vise grips and try to turn it. If that doesn't work, apply heat with a torch to the bolt and use the vise grips to turn it. It sounds like you cross threaded the bolt when putting it back in.
  4. Aug 23, 2013 at 10:22 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Try a bolt extractor socket too.
    Bolt was going in, probably don't need penetrating oil or Heat.
  5. Aug 23, 2013 at 10:23 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Your lucky, there looks to be enough sticking out to get a hold of. Dealership can proly tell you what size and thread count. I got a good extractor set made by ryobi at Home depot. Drill a hole in it and and insert extractor. Then turn out.
  6. Aug 23, 2013 at 10:30 AM
    AvsFanTRD
    Brandon
    Wyoming
    Best part is that it is the most awkward bolt to reach of the plugs. Drivers side closest to the windshield. Just tried vice grips alone and that didn't work. Can't get any leverage.
  7. Aug 23, 2013 at 10:33 AM
    TACO TX
    Kelly
    Denison ,Texas
    PB blaster is a must! Might try channel locks.
  8. Aug 23, 2013 at 11:10 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The bolt is an M6 x 1.0 pitch, measure the length of another one and the replacement one should be easy from there. As for getting it out, try one of those cam style stud extractors on an extension. If it takes more torque than you can apply with vise grips, its probably crossthreaded though, which means it will needs the threads in the valve cover chased at best, or drilled out and heli-coiled at worst.
  9. Aug 23, 2013 at 11:12 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this! i have done this many times. looks like there is enough poking out.
  10. Aug 23, 2013 at 11:29 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    OH you got that thing some kind of crooked no wonder it broke vice grips and a screw driver. Clip the vice grips straight down stick the screw driver between the jaws and see if it will turn. Don't try again with a new bolt until you have chased the threads with a tap.
  11. Aug 23, 2013 at 11:35 AM
    LowerBost
    LowerBost Well-Known Member
    Nick
    Pittsburgh, PA
    09 Tacoma Sport
    Old Man Emu Lift w/ Dakars and Billsteins, K&N Intake, Throttle Body Space, Front Bull Bar, Side Rails, Painted Stock Rims, Bilstein 5100 Front Shocks, Third Brake Light Cover, Satoshi Grill Mod, BHLM Mod
    Don't heat that bolt! You don't heat bolts they expand when you heat it what good is that? You heat nuts that are on bolts.......In this case go with an EZ Out that's probably your best bet. Spraying PB Blaster probably wont do you any good because the bolt isn't even rusted.
  12. Aug 23, 2013 at 11:35 AM
    strip
    strip Well-Known Member
    Bill
    Fort Smith AR
    07 TRD SR5 4x4
    Lift
  13. Aug 23, 2013 at 11:41 AM
    MNStealth13Taco
    MNStealth13Taco Active Member
    Tom
    Rochester, MN
    2013 Black DCSB TRD Sport
    TRD Supercharger TRD Exhaust System TRD Quickshifter w/ TRD Shift Knob Rear View Mirror Lift Bracket Katzkin Leather w/Heat and Ventilation BAK Roll-X Tonneau Cover OEM Tacoma Bed Mat OEM Bed Extender Pop and Lock Power Tailgate Lock Smoke Weathertech Window Vents Black Weathertech DigitalFits 50%F/35%B Tint 265/60R18 Silent Armor Tires on 18" XD Monster Wheels Black Luverne BullBar and BajaStep
    You should probably tape off that plug hole so you don't get any shavings down there too while extracting and re-taping.
  14. Aug 23, 2013 at 11:43 AM
    LowerBost
    Nick
    Pittsburgh, PA
    09 Tacoma Sport
  15. Aug 23, 2013 at 1:16 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    A left handed drill bit will usually remove them by unscrewing them. Take a center punch and make a punch mark in the center and than start the drill, running in reverse of course.. Just Google "left handed drill bit" and you will find many places to buy them.
    Even if the drill does not catch and unscrew the broken piece you will have a hole to use an easy out on.
  16. Aug 23, 2013 at 2:38 PM
    aficianado
    back to bone stock.
    Bolt out
  17. Aug 23, 2013 at 2:52 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Would it be worth the time to take the valve cover off for better access?
  18. Aug 23, 2013 at 3:45 PM
    slowmachine
    slowmachine Well-Known Member
    Alton, NH
    This has happened to me several time on VW diesels. I doubt that you have enough bolt sticking out to use an extractor. I rely on two techniques to get them out. First, get a nut that just fits over the broken bolt shank. With proper shielding, etc., weld the nut to the bolt and wrench it out. If it breaks below the surface of the aluminum casting, I remove the cylinder head and take it to a shop that does EDM, short for Electronic Discharge Machining. They can remove it without damaging the aluminum head casting.
    It is very easy to damage the head casting while trying to drill a broken bolt. Don't destroy the head trying to save the $100 or so for professional assistance. If you're not a welder, look for somebody that does mobile service. It probably costs less than a tow.
    EDIT. Use a washer under the nut if you weld it.
  19. Aug 23, 2013 at 4:59 PM
    AvsFanTRD
    Brandon
    Wyoming
    If I manage to get the bolt out, what size tap do I need?
  20. Aug 23, 2013 at 5:59 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    That looks cross-threaded to hell.
    Get a new bolt and take it to the auto store and say " I need a tap for this bolt"?
    You are just going to have to make the vise-grips work. File two sides a little flat.
