Spark plug bold broke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AvsFanTRD, Aug 23, 2013.
  1. Aug 23, 2013 at 6:12 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Nothing to add that hasn't already been said, all good advice. Just wanted to say that fuckin sucks dude, badly.
  2. Aug 23, 2013 at 7:42 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Metric M6 x 1.0 pitch as landphil stated earlier...
  3. Aug 23, 2013 at 9:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Looks like he cross threaded it and kept cranking.
    Tapping it out is going to be a task best left to someone who knows what they are doing.
    That is a blind hole. You CAN NOT drill it out. Most taps are tapered... the hole is not deep enough for a tapered tap.
    Tapping blind holes is not for the faint of heart.
  4. Aug 23, 2013 at 9:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    same size as the bolt. You just want to "chase" the threads to make sure they aren't damaged.
  5. Aug 23, 2013 at 9:49 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    Are the bolts made of soft aluminum? I didn't know if toyota uses aluminum bolts for low torque areas to limit damage of say a harder metal. The amount of torque needed to break the bolt should have been a huge red flag. First thing my dad taught me, Don't force a bolt in aluminum. They should go back in with no more then what it took to take them out. He was referring to spark plugs but same concept.
  6. Aug 23, 2013 at 10:38 PM
    Nfurtado77
    Nfurtado77 Well-Known Member
    First off try penetrating oil and vice grips but if hat doesn't work weld a bolt onto the stud it's alot less risky than a stud extractor.
  7. Aug 23, 2013 at 11:29 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Looks like he used a vice grip or channel lock to tighten it in the first place. :(
  8. Aug 23, 2013 at 11:36 PM
    Manwithoutaplan
    ID
    I did the same exact thing at the beginning of the year. what cylinder was that on the drive side?
  9. Aug 23, 2013 at 11:37 PM
    Anteupp
    Anteupp Mega Member
    thought I was the only one thinking this lol
  10. Aug 23, 2013 at 11:38 PM
    Anteupp
    Anteupp Mega Member
    this!! works almost everytime, done successfully a few times on my truck, dirtbikes and misc. equipment.
  11. Aug 24, 2013 at 12:32 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Crescent wrench, otherwise known as "Adjustable Metric"
  12. Aug 24, 2013 at 3:03 AM
    toyo8696
    toyo8696 Well-Known Member
    Cumming,GA
    4X4 Sport DCSB, 2008 4R V8 AWD
    Unless he takes it somewhere or knows what he's doing, I see a new valve cover being installed.
  13. Aug 24, 2013 at 3:58 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Oklahoma socket set!
  14. Aug 24, 2013 at 10:03 AM
    Nfurtado77
    Take it to a shop that has a millwright they do stuff like that all the time try and mig weld the nut if you can arc will be a bit more challenging.
  15. Aug 24, 2013 at 10:07 AM
    #35
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    This is exactly what I was going to suggest- even down to the brand. It's what I use. It also doesn't hurt to have some cutting fluid handy when you are drilling the hole.
  16. Aug 24, 2013 at 10:30 AM
    #36
    AvsFanTRD
    AvsFanTRD [OP] Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    rear driver side or closest to the cab, however you want to look at it.
    The one that is the biggest pain to get to.
  17. Aug 24, 2013 at 10:43 AM
    #37
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    If you cant get a welder, you could also run the nut down onto the broken bolt, and then use a punch and punch the threads to lock the nut on.
    Or get a torch and run some solder in between the nut and broken bolt. You don't need much and don't let it drip down past the nut.
  18. Aug 24, 2013 at 11:45 AM
    #38
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    goto autzone and rent a metric stud remover kit
  19. Aug 24, 2013 at 11:47 AM
    #39
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    racis
  20. Aug 24, 2013 at 2:29 PM
    #40
    Rich91710
    Rich
    Los Angeles
    08 Base
    Guys... he's got the broken part out already.
    Just needs to repair the threads and install the new bolt.
