Spark Plug Change info...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jimsc, Feb 3, 2014.
  1. Feb 3, 2014 at 4:33 AM
    Jimsc
    Jimsc [OP] Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    My 4.0 L has 38,000 miles so I decided to change the spark plugs. It was not necessary to remove anything except the air filter box on the passenger side. The drivers side looked harder than the passenger side so I started there. All plugs looked good and probably had many more miles left on them. The drivers side had 3 NGK and the passenger side had Denso. All the NGK had a little more ware(more gap) than the Denso's.
    Installed 6 Denso's I bought from the dealer ($3.50 each). Took my time and installed anti-size and boot lube on all plugs. Took about an hour.
    Great way to get to know your truck a little better!
  2. Feb 3, 2014 at 5:07 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Good to hear it's not too hard.
    I plan on putting a set of iridium's in my truck at around 30k. :D
  3. Feb 5, 2014 at 4:02 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    Did you buy the truck used? It sounds like some lazy kid only replaced the"easy" plugs at a past tune-up.
  4. Feb 5, 2014 at 7:46 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Yep Jim,
    I had the same experience when I changed them back when I had my 2011. The NGK were worn more than the Denso's which leads me to believe the Denso plug is a better plug for our truck. Pretty easy to do with the right tools and like the post above, Chris4x4 did a excellent write up and I just followed his advice with no issues at all. My wife helped me and would hand me the tools which saves a huge amount of time.
  5. Feb 5, 2014 at 9:07 AM
    degu2000
    degu2000 Well-Known Member
    Mine doesn't know the difference between a wrench and a table saw.
  6. Feb 5, 2014 at 9:49 AM
    RearViewMirror
    Craig Christ
    Haha.. Mine didn't either until I laid everything out and explained what each one does and their name. She actually was a huge help and probably knocked off 30 mins of time. It's nice having someone there with a tool at the ready.
  7. Feb 5, 2014 at 11:14 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Every vehicle I've ever owned has had aluminum heads. Have always used 3-in-1 oil on spark plug threads, most have had over 100k miles and no problems.
    Question - how much anti-seize to use rather than oil ? Cover first 3-4 threads at electrode end or ???
    Just don't know how much (and I did search both here and other sites but no recommendations).
    Thanks
  8. Feb 5, 2014 at 11:18 AM
    RearViewMirror
    Craig Christ
    I put anti-seize on the threads with the exception of the bottom 2 threads. I didn't want to take a chance of anti-seize getting into the combustion chamber (not that I think it would hurt anything).
    *EDIT* Since our trucks use copper plugs you need to change them at 30k. Some people use Iridium but I personally wouldn't as our trucks weren't designed for them.
  9. Feb 5, 2014 at 11:39 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    So the anti-seize gets pushed down as the plus is threaded in? I also thought about just doing 3-4 "stripes" of anti-seize vertically from electrode end toward the porcelain so it would spread horizontally to uncoated portion of threads when plus is installed, concern, like yours, is not to use too much.
  10. Feb 5, 2014 at 11:42 AM
    RearViewMirror
    Craig Christ
    Yeah... it doesn't take much. Like I said... the way I did it was 2 threads up from the electrode to the top (porcelain). I don't think it would give any problems if a little got in the combustion chamber but I'm so damn OCD that I just like things done the way I want them done lol.
  11. Feb 5, 2014 at 12:26 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    It's crazy how the prices of the Denso plugs can be vastly different from one dealership to another. I was originally going the eBay route on the OEM Denso plugs at $4-$5 / piece after calling a local Toyota dealership(Toyota of Grapevine), whom quoted me a whopping $7.48. Just for grins, called Freeman toyota in Hurst, quoted $3.47 /each. Wow, what a difference!
  12. Feb 5, 2014 at 12:43 PM
    RearViewMirror
    Craig Christ
    Yeah... that's crazy. I think I paid right around $4 per plug when I bought mine. Funny thing was... when I bought them I told him I needed 6 plugs for a Tacoma. He asked was it a 4 or 6 cyl. I told him 4. I'm just buying 2 more in case I happen to break 2 of them :rolleyes:
