Spark plug change is this normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CLVol1255, Apr 7, 2023.
  1. Apr 8, 2023 at 7:53 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I am at a loss how Fufu delicate these trucks are. Changing plugs at 60k miles? Back in the days of real Toyota built trucks from Japan, you could easily remove the plugs, inspect and re-space them, and if OK you could just clean them up with a little wire brush and stick them back in.
    22Coma6MT and Stevie17 like this.
  2. Apr 8, 2023 at 7:58 AM
    OnHartung'sRoad
    OP’s plugs would’ve been reused with just re-spacing them and cleaning them up if it were my ‘85. I do have to admit, though, that one plug on the lower left-hand corner has a lot of carbon buildup, showing that the plug was compromised and probably wasn’t sparking very well in that cylinder. I wonder which cylinder that was from? I’d pressure check it
  3. Apr 8, 2023 at 7:58 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That was the old day of copper plugs. You ain't taking sand paper or a wire brush to these new type of plugs they got out there.
  4. Apr 8, 2023 at 8:00 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    The Atkinson Cycle type of engine in the Tacoma is the reason the spark plugs are only meant to go 60,000 miles. The direct injection and the cleaning cycles put more wear on the plugs and probably why they should be changed earlier. That is my guess anyways.
    Stevie17 and brian2sun like this.
  5. Apr 8, 2023 at 8:02 AM
    OnHartung'sRoad
    Oh geez, dude you fell for it. There’s no reason why plugs need to be so expensive, the spark gap is what matters.
    They could easily use the old style plugs as well, as long as the resistance from the connector plug to where the spark gap is correct.. But yeah, if there are alloys that make the spark work better in the tip of the spark plug I guess that’s part of it, but seriously we are all victims of this.
    Stevie17 likes this.
  6. Apr 8, 2023 at 8:04 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    GarrettTacoma, Jesse46 and Stevie17 like this.
  7. Apr 8, 2023 at 8:05 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Uhhh, fell for it? Plug technology has come pretty far. You don't adjust or even touch iridium tipped plugs or the like. Today's modern engines will tear up old copper plugs, so they had to design and manufacture something different to hold up. Hell, the 2nd gen Tacoma's had copper plugs and the intervals are 30K. The new plugs are twice as expensive, but last twice as long. So, not much difference...
  8. Apr 8, 2023 at 8:07 AM
    OnHartung'sRoad
    The only technology in a plug is the fancy metal they put on the tip, the spark is the same as Electrons have not changed any since I started driving. Now, if you’re talking about materials that keep the spark plug lasting longer that’s different but really, the physics of it are exactly the same.
    Rusty66 likes this.
  9. Apr 8, 2023 at 8:09 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Correct. But complaining about changing plugs and not being able to just clean them, that's just neglect IMO...
    RustyGreen, Laxtoy, Junkhead and 4 others like this.
  10. Apr 8, 2023 at 8:09 AM
    CLVol1255
    CLVol1255 [OP] Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    The worst looking plug came from passenger side next to firewall. Very first plug I removed
    Stevie17 and HondaGM like this.
  11. Apr 8, 2023 at 8:10 AM
    OnHartung'sRoad
    I think they make them hard to pull out so we won’t do it and just clean them. buying new ones from a dealer and paying them to do it is the way to go these days I guess.
    Stevie17 and CLVol1255[OP] like this.
  12. Apr 8, 2023 at 8:12 AM
    OnHartung'sRoad
    yeah, as others pointed out, you waited too long, and the carbon uildup on the sides of that plug were probably causing the cylinder to not burn the fuel as efficiently as the spark, probably partially traveled down the sides of the plug rather than the full amount going across the gap.
    I remember seeing a demo of this along time ago, you could pull the plug out that was dirty and fire up your engine and see the sparks traveling on the sides of the plug rather than across the gap if it was a very dirty one.
    sorry, I’m using text to speech, got to get back to driving I guess.
  13. Apr 8, 2023 at 8:16 AM
    OnHartung'sRoad
    If they were easy to pull out, I would’ve done it at 30,000 inspected them but no longer these days. I hate certain things about these tracks and this is one of the big ones.
    Junkhead, Stevie17 and CLVol1255[OP] like this.
  14. Apr 8, 2023 at 8:17 AM
    OnHartung'sRoad
    OP. If you’re worried about it next time you pull those out have a compression check of the cyllendars, it’s probably OK it’s just that you let the one get overly dirty.
    OK I’m out luckily I’m just a passenger but this road is really bumpy. Have a good day you guys.
  15. Apr 8, 2023 at 8:47 AM
    #35
    twtaco$
    twtaco$ Well-Known Member
    Yeah this proves change at 100k!!
    CLVol1255[OP] likes this.
  16. Apr 8, 2023 at 8:53 AM
    #36
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Well I took a wire brush to them and they look almost good as new minus the new shine. I may actually sell these old plugs on the marketplace lol
  17. Apr 8, 2023 at 9:28 AM
    #37
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I wouldn’t worry about it.
    if you’re really anal about it, just check the spark plugs you put in at 20,000miles and see how they look.
  18. Apr 8, 2023 at 9:29 AM
    #38
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    a sample size of 1 negates anything published by a massive corporation full of highly-educated paid engineers?
    fair warning, the manual never says you must change the plugs at 60k, but there's a reason they have it there.
    this is like arguing over bake pad changes. a disc brake caliper piston is well documented to have similar stopping performance as the brake pad material in most cases. so now you don't even need those BS brake pads toyota keeps trying to sell you!
  19. Apr 8, 2023 at 9:36 AM
    #39
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    These folks are just trolling. If not they are outright neglectful to their trucks.
    It would be similar to "I only feed my dog 2 days a week. He survives just fine and I save so much money!"
  20. Apr 8, 2023 at 9:49 AM
    #40
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lol yeah we're all victims because it's suggested we change plugs at 60k. The tyranny of those dang toyota engineers
