Spark Plug Change....WOW
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PPower05, May 12, 2013.
  1. May 12, 2013 at 2:11 PM
    PPower05
    PPower05 [OP] Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Hi all,
    Just got done doing a spark plug change on my 2010 TRD Off Road DC.... WOW! Truck has a little over 49000 miles, and I was hesitant in doing it, but with the awesome write ups, it was easy! Took me a little over 1.5 hours to do both sides, my gaps where anywhere between .058-.060... To anyone who is thinking about doing it, do it! So easy to do!
    Thanks all!
    PS- Used NGK Iridium IX's... A little pricy, but with a newborn at home, cant work on the truck as much as I used to... No issues to report so far!
  2. May 12, 2013 at 2:22 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    hope they work well for you, glad to see that they are ngk!
    just incase though its generally thought that the factory plugs are best, but I recon that only comes from those of us to scared to try something else
  3. May 12, 2013 at 2:28 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Factory plugs ftw
  4. May 12, 2013 at 5:37 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The plugs are a breeze on this truck. Next time you'll have it down to under a half hour.
  5. May 12, 2013 at 5:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ive tried more plugs than you could imagine. The OEM plugs give best performance.
  6. May 15, 2013 at 2:52 AM
    PPower05
    Perry
    Ranson, WV
    2010 SR5
    I dont doubt that they do give the best performance, however, it is the service intervals that kill me... You would have thought that I had to beg/barter/steal to get even 2 hours to work on my truck.... It is just for now, I figure that it is better to have new plugs with proper gaps than stick with the old stock ones... I am not one that puts too much into the whole "performance through sparkplugs" belief, the main reason is due to the longer service intervals.
  7. May 15, 2013 at 3:42 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    No worries about ur heads?
    Pretty sure the dealer threw irids on when they put on the force fed mod, but im still pulling them in 30k.
    Cheap insurance
  8. May 15, 2013 at 6:20 AM
    Brandon###
    Brandon### Well-Known Member
    i swapped to iridiums at 30k and have had great results. the pinging i used to have is gone and 40k miles later i still have 60k left until i swap the plugs out again.
    IMO, the oem plugs are cheap and don't last long at all.
  9. May 15, 2013 at 6:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Copper plugs are better conductors, and give a hotter spark. If you are supercharged, then you need a cooler plug to prevent detonation.
  10. May 15, 2013 at 6:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cooler plugs, unless required, can lead to excess NOx, thus leading to carbon buildup on the pistons.
  11. May 15, 2013 at 7:01 AM
    Brandon###
    No doubt that copper is the best conductor, but they don't last long at all.
    Are you saying that iridium or platinum provides insufficient spark for the 4.0?
    all of the dual vvti's come with iridiums from the factory
  12. May 15, 2013 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The ones that come with them have an ignition system designed for them. The ignition on the Tacoma's 4.0 is designed for the copper/Nickle plugs. Best performance and milage is had with them.
  13. May 15, 2013 at 10:13 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    the OEM copper plugs are like $2 each. Just put OEM in and change them every 30k. You will get better performance and will satisfy Toyota's recommendation.
  14. May 15, 2013 at 11:02 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    my spark plug change "nervousness" levels are directly proportional to the length of time the plugs have been in place.
    when a friend comes to me to help him/her change out 100k mile spark plugs i get damn nervous. i've seen them strip out too many times. (mostly ford F150's)..i hate it.
    on that alone, i always reinstall the vanilla copper NGK or Denso..i dont want them to get to comfy in that head. hahaa.
  15. May 15, 2013 at 2:40 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    The Fords are notorious for stripping or breaking because of the shitty design hence why even the dealer sells the removal tools for when that happens. Tacomas are a breeze, my first time was 45 mins taking my sweet time.
  16. May 15, 2013 at 3:42 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Huh?
  17. May 15, 2013 at 3:49 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The ideal with the 30K is for emissions warranty. If you don't and trash a converter Toyota will cry foul. MHO they should last at least 60K but if you want to keep the emission warranty intact you got to change them.
  18. May 15, 2013 at 4:48 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    If they made a copper plug that lasted 100K i still wouldnt buy it. I am paranoid about seized plugs in the head and like getting them swapped out more regularly. I use anti seize on everything.
  19. May 15, 2013 at 4:51 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    What is the general concensus on the E3 plugs
  20. May 15, 2013 at 10:05 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Stacey David loves em!
