Spark Plug Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Overheadspec, Nov 24, 2008.
  1. Nov 24, 2008 at 6:04 PM
    Overheadspec
    Overheadspec [OP] Member
    Houston, TX
    08 Prerunner Longbed
    Does anyone know what the Dealership charge is to change out spark plugs?
  2. Nov 24, 2008 at 6:33 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Have you called them to get a quote yet?
  3. Nov 24, 2008 at 7:05 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    They are easy to do yourself. I'm not a master mechanic by no means. But I was able to do it. One place quoted me (because I was lazy & didn't feel like doing it. Until they gave me the price) I think it was $150.
    It was easy to do myself. Took me about 45 minutes. The drivers side was the most difficult.
  4. Nov 24, 2008 at 7:14 PM
    Overheadspec
    Houston, TX
    Just wasn't sure how hard it would be. I do basic maintenance myself, but I have never changed out spark plugs. Other trucks I have had came with longer life plugs. Any advice on changing them myself?
  5. Nov 24, 2008 at 7:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    very simple man. be sure to get some anti seize and put just a bit on the threads...and dont torque them down too tight....just snug them down, then maybe a quarter turn. the coil packs are easy as pie to get off too. you will need a couple of long extensions and a 5/8ths spark plug socket also.
  6. Nov 24, 2008 at 9:12 PM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    but I do know that I have a set with 12K miles on them, ready to ship!
    You pay shipping only!
    They were removed when I installed the TRD S/C...
    -6- Denso Iridium FK20HR11 (used 12K miles, like new, in box with thread covers)
  7. Nov 24, 2008 at 9:26 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    NEVER do it when the engine is warm. Heat generally = softer metal = cross threading. Also, always start them by hand until they won't turn and then use a wrench.
  8. Nov 25, 2008 at 3:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Not a good idea to re use plugs. The crush washers ar already crushed, and re installing them in a different engine may cause them to strip the head. (Been there, done that:()
  9. Nov 25, 2008 at 5:49 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    I just too a peek at my engine before driving to work. I can see the coilpacks, but there's all kinds of sh*t in the way on the driver's side. Has anybody done a play-by-play with pictures on a spark plug change? I really want to add this to the list of things I can do myself, but I don't want to f-up my truck in the process.
  10. Nov 25, 2008 at 5:52 AM
    P. Bauer
    San Jose
    Interesting. I've never heard of anybody stripping their head due to using sparkplugs that were installed in another engine prior, but the same model/type/brande etc. I've taken plugs out to examine them on other engines (13B Rotary) and reinstalled them with no issues.
    These plugs were installed and then removed after ~12K miles.
  11. Nov 25, 2008 at 6:02 AM
    P. Bauer
    San Jose
    It's pretty straightforward, make sure you have some extensions 6"/3" for your 3/8" ratchet, as well as a universal joint. I remember moving some of the vacuum hoses to gain access, just mark them and you should have no trouble replacing them.
    Also, torquing the plugs: General rule for spark plugs - after they seat, 1/2 turn for plugs w/new washers, 1/8 turn for plugs w/o washers or reinstalling plugs, or about 14 lb/ft. I personally don't use anti-seize on the threads, some do, some don't. YMMV.
  12. Nov 25, 2008 at 8:07 AM
    Hadoken
    Hadoken Active Member
    Us RX-7 owners know all about pulling plugs to check them!! If yours is an older one like mine, you do it almost as often as pulling the dipstick ;)
    Just make sure you don't get any Autolite spark plugs near that 13b...
  13. Nov 25, 2008 at 9:28 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    Not that I am going to be doing this to my 09 anytime soon but I am so glad not to see any threads about "how to change #X plug". On my past couple of vehicles there were always one or more that required major tricks and/or luck to get at. For instance # 2 on my LT-1 Camaro. That one plug took me several hours to change last time. Not to mention dropping the y-pipe to get the rearmost plugs from below. And the dealer quoted 8 hours of labor for a plug change. On my old S-10 V-6 it was #3 being obstructed by the steering shaft, although mine wasn't as bad as most. Looks like the Tacoma will be a relative POC. :)
  14. Nov 25, 2008 at 11:26 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    **shudder** plug change in LT1 Camaro....:eek:
  15. Aug 23, 2010 at 3:49 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    One tool not listed in the write up is a telescoping magnet. I found it very useful to extract the plugs. I even used it on the install.
  16. Aug 23, 2010 at 3:56 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    What is the gap space for our truck?
  17. Aug 23, 2010 at 4:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    between .039 and .043.............set it at .040, and call it good. and dont forget a lil anti-seize on the threads.
  18. Aug 23, 2010 at 4:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A quality (and most cheap) spark plug sockets have a rubber peice that "snaps" to the plug for removing, and re insertion. A telescoping magnet isnt necessary.
  19. Aug 23, 2010 at 7:10 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I didn't see it posted elsewhere in this thread. Here you go.
    http://www.tacomaworld.com/forum/technical-chat/30479-how-spark-plug-change-1-gr-fe.html
    This write up makes it seem harder than it is. If you have a really long extension like 18 - 24 inches it makes it VERY easy to do the drivers side. I did it in about a half an hour, but I have the use of air tools & wobbly sockets.
    EDIT: Holy thread ressurection!!!! My bad.......
  20. Aug 23, 2010 at 7:18 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Another note: after you pull the cables off the plug, blow some compressed air around the plug to get rid of some dirt before you remove the plugs. This prevents any of that crap getting into the engine. I'm not sure if anyone alreayd mentioned, but use some dielectric grease on the cable where it connects to the plug...promotes a good electrical contact and prevents corrosion.
