Spark plug ejected on my 3.5L, stripped head
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DarkTaco413, Jun 30, 2025.
  1. Jul 2, 2025 at 11:57 AM
    #41
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    I reason i ask is i guess the one on the drivers side at the back is hard to get at'
    I have no idea how they install the fix.
  2. Jul 2, 2025 at 9:00 PM
    #42
    victorneyra
    victorneyra Active Member
    do sert and trade
  3. Aug 14, 2025 at 8:37 AM
    #43
    DarkTaco413
    DarkTaco413 [OP] Member
    2017 TRD-S DCSB MT blk
    Update: Found a shop that stocked and regularly installed Helicoil Save-A-Thread solid inserts, had them do the job and also replace rest of the plugs. Everyone who said do a Time-Sert, I think you were right about it being the better option, but I'd rather have them do a job with the kit they're comfortable with than change it up on them for a slightly better repair.
    Mechanic said the other 2 plugs on the stripped side were tight, but all 3 on the other side were loose - all factory installed plugs.
    Truck runs better than before! It's subtle but the idle feels and sounds smoother and maybe a slightly more consistent power delivery or I could be imagining that.
    Here's hoping the insert holds while I figure out what I'm doing with the truck. Running really well so I'm tempted to keep it, already did an 8hr trip with a decent payload and no problems. But there's the uncertainty.. so I'll probably be looking at sale/trade soon. Will update the thread if it pops or whatever.
    ~200 for the insert and install plus avg cost for rest of the plugs. Feeling pretty lucky but not getting my hopes up.
    Thanks for all the guidance!
  4. Aug 14, 2025 at 8:40 AM
    #44
    eurowner
    eurowner Duke Sky
    Scoty
  5. Aug 14, 2025 at 8:49 AM
    #45
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I like hearing about updates like this. Thanks for reporting back on it, it helps for future people that experience the same problems.
  6. Aug 14, 2025 at 9:07 AM
    #46
    Sungod
    Sungod Well-Known Member
    St Augustine
    Great reasoning on the decision to go with the helicoil. I have used them in the past with no issues and they have been around a long time. The other one may be better, but if the helicoil does the job, better is meaningless.
    Solid information all the way from @slater He really gave good advice.
    SR-71A likes this.
  7. Aug 14, 2025 at 10:27 AM
    #47
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    I agree, especially if you cant find someone in your town that's using them...
    You tried!
    The purchase price for the toolage is costly & im sure if the shop has using the solid insert from heli-coil with success & they have confidence in it, it is what it is...
    Sounds like you got it handled, didnt have to throw a head at it!!!
    Thanks...
  8. Aug 14, 2025 at 10:42 AM
    #48
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Funny enough time-serts were called in a Toyota TSB for 2AZ-FE engines where the head bolts pulled threads from the block. It affected a large number of Toyotas (2nd gen RAV4s et al). That was 20 years ago, so I guess the Toyota dealers in OP's area no longer have the tools or anyone left that knew how to use them.
    eurowner likes this.
  9. Aug 14, 2025 at 12:38 PM
    #49
    slater
    San Diego
    Theyre superior to anything else out there!!!
    Thats not me just being a fanboy, I was scared of them at first....
    Someone much smarter than me brought the kit into the dealer service dept. He was another engine line mechanic at one point, became shop foreman & then service manager....
    The way the lock the insert in, driving the oblong / expanding threaded tap through the insert locks it in better than anything else on the market...
    3JOH22A[QUOTED] likes this.
  10. Aug 14, 2025 at 5:30 PM
    #50
    MGMDesertTaco
    It'll be interesting to see how this holds up with heat cycles. Hopefully it does.
  11. Aug 14, 2025 at 6:30 PM
    #51
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Maybe this is just my tinfoil hat talking. But did they remove a plug to check them for age when they recommended them? Not entirely out of the question that when you declined, the tech just ran the plug back in without tightening it.
  12. Aug 14, 2025 at 6:40 PM
    #52
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Not sure where you are going with this, but engines came from Kentucky plant with plugs installed
  13. Aug 15, 2025 at 6:52 AM
    #53
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Nah, the affected cyl 4 is in the middle of the driver's side bank, with hoses and brackets in the way. If a mechanic wanted to sample a plug, he would've picked a passenger side cylinder for easier access.
    The service writer was just pushing the service because the book interval is 60k.
    5nahalf[QUOTED] likes this.
  14. Aug 15, 2025 at 7:26 AM
    #54
    DarkTaco413
    Wasn't going anywhere with it, just a data point, and I was actually wrong anyway lol.. driver's side sticker says Texas. Didn't realize the plugs aren't installed there though
  15. Aug 15, 2025 at 7:36 AM
    #55
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Now that an engine replacement has been avoided, you should direct your attention to the other maintenance item due at 120k - vacuum pump vane replacement. It entails unbolting the transmission mount and tilting the engine forward...
  16. Aug 15, 2025 at 10:47 AM
    #56
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Has anyone actually replaced their vacuum pump on time? I'm over due and when I was at my local toyota dealer last year buying coolant I asked them if they've seen them fail or if it's a liability thing because it's related to the brakes... advisor asked their two head techs who said "Tacoma's have never had vacuum pumps"
    ... my fault for asking them a question...every time I do I get a wild answer that doesn't compute...
    Prior to that I went to get more red coolant where they told me they haven't sold it since 2013. 3 days prior I was there buying a jug of red coolant. Before that I went with the magnet of my a/c compressor that was new and not even installed yet where they repeatedly told me they could only test for it being seized on the vehicle. I agreed buy explained it was the magnet and not the bearing and had my multimeter live to show them a reading of 0 ohms which yielded a response of "you can't check those like that, it has to be on the vehicle". They warrantied it still " as a favour"
    3JOH22A[QUOTED] and usmc2msu like this.
  17. Aug 18, 2025 at 7:38 AM
    #57
    DarkTaco413
    Noted, thanks for the heads up. What's a reasonable cost to do this since it's beyond my skill/equipment level?
  18. Aug 18, 2025 at 8:20 AM
    #58
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Call around a few shops. :notsure:
    (I have a TRD Off Road, which doesn't have the vacuum pump.)
