spark plug electrode
Discussion in '1st Gen. Tacomas (1995-2004)' started by brock, Dec 7, 2008.
  1. Dec 7, 2008 at 12:19 PM
    brock
    brock [OP] Member
    colorado
    tacoma
    Hello all,
    I've got a 98 with 107k. mi. yesterday while driving the engine started making a loud knocking noise. I decided to pull the spark plugs and discovered on one of them that the electrode had broken off and now resides somewhere inside the engine. What would have caused this to happen? and how should I proceed?
    Thanks Brock
  2. Dec 7, 2008 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats why plugs need to be changed frequently. What engine do you have? Im guessing your gonna have to pull the head off, and inspect for damage.
  3. Dec 7, 2008 at 2:45 PM
    brock
    brock [OP] Member
    colorado
    tacoma
    Hi Chris,
    the engine is the six 3.4 Litre engine, the plugs have been in for 2 years, and its not a daily driver. I was thinking of removing the head, is there any good tutorials on this forum for this procedure?
    Thanks Brock
  4. Dec 7, 2008 at 3:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cjheck this out for the FSM on your engine:
  5. Dec 8, 2008 at 3:24 PM
    offset442
    offset442 Member
    just stick a really strong magnet and pull the plug core out, then do a compression test, if it looks good run it, the chips of ceramic will just blow out on there own, chances are the head and the pistion are pitted, big deal, it will live you just need to make sure you get the metal core out of the equation or it will ping around until the end of time
  6. Dec 8, 2008 at 4:02 PM
    brock
    brock [OP] Member
    colorado
    tacoma
    Hey thanks,
    I tried a small tube hooked to a shop vac, but it didn't look like anything came out, tried to wiggle it around as much as possible and still nothing. I then blew some compressed air and something did blow out but I could not find it.
    I'll see if I can find a strong magnet or magnetize something that I can tie a string to.
    Would it be a bad idea to spray some carb cleaner or other liquid in there and then try the above vac/air procedure again?
    Also I noticed that the treads are stripped out of the cylinder head. I was thinking of trying that Time Sert (www.timesert.com) anyone tried this for rethreading?
    Brock
  7. Dec 8, 2008 at 5:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2
