Spark Plug Erosion
Discussion in '4 Cylinder' started by Model 70, Feb 19, 2012.
  1. Feb 19, 2012 at 5:37 PM
    Model 70
    Model 70 [OP] Well-Known Member
    Central Oklahoma
    97 Tacoma 4X4 Pristine Clean
    JRS leaves, Monroe Redi Struts., Later Taco Mini Header, Alpine Tunes.
    I have a '97 Tacoma with 2.7 engine. Mileage is 217,000. Oil changed every 3000 miles.
    I pulled these Split Fire plugs which the PO had installed and replaced them with Denso plugs and new wires.
    Any ideas why plugs 1 and 3 would be so eroded on tips while 2 and 4 were not?
    I performed a compression check on the engine while I had the plugs out with the following results:
    Cold engine:
    #1 175 psi
    #2 160 psi
    #3 150 psi
    #4 190 psi
    Warm engine:
    #1 200 psi
    #2 187 psi
    #3 185 psi
    #4 195 psi
    I am wondering if compression tester that I am using is out of calibration as these numbers seem a little high.
  2. Feb 19, 2012 at 5:47 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    From the FSM:
    Compression pressure:
    1,230 kPa (12.5 kgf /cm2, 178 psi) or more
    Minimum pressure:
    880 kPa (9.0 kgf /cm2, 127 psi)
    Difference between each cyl inder :
    98 kPa (1.0 kgf /cm2, 14 psi) or less
  3. Feb 20, 2012 at 5:15 AM
    Model 70
    Central Oklahoma
    Thank you for the reply on the compression numbers. The other question about the spark plug erosion still bothers me. Could I have a coil pack that is getting weak on cylinders 2 and 4? Or is there a problem with spark on 1 and 3?
  4. Feb 20, 2012 at 5:54 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It could just be that they were in the engine too long. The Split fire number cross references with Denso/NGK stock numbers so they should be with in the heat range. The chart below mentions poor fuel economy could cause the electrode erosion. That might suggest the may be the injectors need cleaned/replaced. Perhaps the fuel filter as well.
