Spark plug gap?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2001 Basic Taco, Oct 16, 2018.
  1. Oct 16, 2018 at 5:09 PM
    2001 Basic Taco
    2001 Basic Taco [OP] Active Member
    2001 Toyota Tacoma 2.4l (Base model)
    Intake, exhaust
    2001 Toyota Tacoma 2.4l (base model) spark plug gap?-Thanks!
  2. Oct 16, 2018 at 5:12 PM
    2001 Basic Taco
    Intake, exhaust
    ...also any recommendations on what spark plugs I should purchase? NGK, Bosch etc.? Don’t need anything crazy, just reliable.
  3. Oct 16, 2018 at 5:36 PM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    The oem Denso/NGK plugs you can get off Amazon are all you need for the 2rz, allegedly they are pre gapped but I've never confirmed. I buy, put em in and go.
    2001 Basic Taco[OP] likes this.
  4. Oct 16, 2018 at 6:20 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    only get NGK or Denso sparkplugs for your tacoma
    Gap is 0.044". They are supposed to come pre-gapped but I like to check the gap before installing, just in case
    Then you have sparkplug types:
    Be it copper, platinum or iridium plugs, they are all the same, but the difference is in how long they last.
    Don't go believe stuff like any particular type will give you more HP, that's bullshit. Though, fresh sparkplugs will improve your MPG if you have old worn out plugs
    Copper are the cheapest but they also have the shortest lifespan. They must be replaced at about 30k miles intervals
    Platinum have a longer lifespan, needing to be replaced at about 100k miles
    Iridium are the most expensive of the bunch, but they can last for 120k+ miles
    2001 Basic Taco[OP] and Petrol like this.
  5. Oct 16, 2018 at 11:47 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I buy the Denso Iridium’s. Last time I did a tune up I checked and they were close enough to .044 so I just installed them and they’re fine right out of the box.
  6. Oct 17, 2018 at 3:25 AM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    NGK and Denso have been my choice for more than 30 years and Denso is a slight favorite.
    As for the gaps being pre-set, I've always set them myself regardless of any claims that they come "pre-set".
  7. Oct 17, 2018 at 5:36 AM
    2001 Basic Taco
    Intake, exhaust
    Thanks for the replies, I appreciate it. I went with NGK G-Power Platinum Spark Plug. If I get anywhere close to 100k I’ll be happy. It’s for my work truck so didn’t want to spend twice as much going with iridium.
  8. Nov 5, 2019 at 2:06 PM
    InAComa2004
    InAComa2004 Well-Known Member
    2004 Toyota Tacoma(Base)
    RockAuto.com sells the NGK G-Power for 12.86 including shipping.
  9. Jul 17, 2020 at 1:44 PM
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    I'm a little late to the party but since it came up in a google search for myself, I figured others could use the info. These are the plugs that were recommended out of my owners manual and from what I've read you're best off using OEM. https://www.summitracing.com/parts/dnp-3491
    I have a 2017 DCSB 3.5L 4WD Tacoma SR5 AT but the only distinction you need to worry about is engine size. If you have the 2.7L engine there is a different recommended spark plug also made by Denso, check your owners manual.
  10. Oct 5, 2022 at 12:10 PM
    TacoSeasoning500k
    TacoSeasoning500k Member
    Thanks for the info. Saved me a lot of trouble. 08 taco with 202k miles and I just changed the plugs. Pretty sure they’ve never been changed. You decide. Old ones measured in at.075. Wow
    xLOGREx likes this.
  11. Oct 6, 2022 at 6:58 AM
    mte
    mte Well-Known Member
    1999 Tacoma v6
    Speaking of plugs...I thought the plugs were supposed to be the dual tips...?
  12. Oct 6, 2022 at 7:00 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    They are supposed to be dual, but plenty of people run single, like myself.
  13. Oct 6, 2022 at 7:03 AM
    mte
    1999 Tacoma v6
    So please educate me as to one way or the othero_O
