Spark plug getting harder and harder to turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by droflakcin, Mar 10, 2019.
  1. Mar 10, 2019 at 10:57 AM
    droflakcin
    droflakcin [OP] Member
    06 Black Tacoma 4.0L
    Changing plugs on my 06, decided to start where I’m having a misfire (#6) I go to loosen the old plug, and it started getting harder to turn...
  2. Mar 10, 2019 at 10:59 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    It's fine...
    Keep turning counter clockwise.
    BillsSR5 likes this.
  3. Mar 10, 2019 at 11:00 AM
    droflakcin
    It’s to the point where it’s nearly impossible to turn...
  4. Mar 10, 2019 at 11:06 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Ruh roe! Try going back in with it. Is it still tight? Spray some penetrating oil into it and slowly work the plug loose and tight back and forth. If it feels like its going to brake STOP!
    Shelf Life, TomTwo, BillsSR5 and 2 others like this.
  5. Mar 10, 2019 at 11:07 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    May have been cross threaded, or no anti seize on installation. How long have they been in there?
  6. Mar 10, 2019 at 11:08 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Do you a thread chaser and a vacuum? If you are worried about it being mangled, soak it in penetrating lube and try to back it out slowly. Forward-back-forward until it comes out. Chase the threads carefully and do not force anything. Clean up any shaving before you put a new plug in.
    I didn't know about thread chasers until I had an issue with an O2 sensor. Great idea to clean up the threads on spark plugs before reinstall even if they come out smooth.
    desertrunner24 likes this.
  7. Mar 10, 2019 at 11:11 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You are between a rock and a hard place it sorta has to come out and it's going to bring a few treads with it. It can be repaired but not with a plug in it. You may as well pull the rest out too and put some anti seize on them this time. Another good reason to change 4L plugs every 30K.
    wilcam47 and Lester Lugnut like this.
  8. Mar 10, 2019 at 11:12 AM
    droflakcin
    Bought the truck two weeks ago. Started getting rough idle and flashing CEL, Got the codes and it’s cyl 6 misfire. That’s why I’m doing it now. Idk when the last time they were changed.
    scottalot and PzTank like this.
  9. Mar 10, 2019 at 11:13 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    What month/year was the truck built?
    PzTank likes this.
  10. Mar 10, 2019 at 11:16 AM
    Muddinfun
    Muddinfun Well-Known Member
    Is the coolant low?
    b_r_o, PzTank and desertrunner24 like this.
  11. Mar 10, 2019 at 11:21 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    You might want to check your oil too for any coolant contamination, coolant level too.
    Early model year '06 4.0s have an older head gasket design that has a higher susceptibility to failure than the average vehicle.
    Good luck, work that plug slowly, use penetrating oil.
    BTW, I changed my '15 plugs at 59K miles, even then they felt a bit 'tight' coming out..
  12. Mar 10, 2019 at 11:22 AM
    droflakcin
    08/05
  13. Mar 10, 2019 at 11:24 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Not sounding good. I would suspect a head gasket. Good news is that the spark plug can be fixed with the head off a lot easier.
  14. Mar 10, 2019 at 12:22 PM
    Skyway
    Ande'
    St.Pete
  15. Mar 10, 2019 at 12:24 PM
    Skyway
    Ande'
    St.Pete
    I have had some really tight sparkplugs in Toyota motors before...
    Always that last one....
  16. Mar 10, 2019 at 12:26 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    soak it with penetrating oil, let it sink in, try to screw it back in, let it sit, then slowly try again to unscrew
    cruxofthebisquit likes this.
  17. Mar 10, 2019 at 12:34 PM
    droflakcin
    UPDATE:
    So I used PB blaster and its turning now, however... I’ve been turning it for what seems like forever and I don’t think I’m getting anywhere. (Yes the socket is on the plug) is it possible that my socket is stuck in the tube? If so, is there any way to extract it??
  18. Mar 10, 2019 at 12:37 PM
    Tacoma Mike
    Southern Maine
    Did you swap coils before trying to replace the plugs ?
  19. Mar 10, 2019 at 12:38 PM
    Tacoma Mike
    Southern Maine
    If you went till it was real hard turning you have done damage.
  20. Mar 10, 2019 at 12:39 PM
    Tacoma Mike
    Southern Maine
    Ooops sounds like you just cost your self a big bill.
