Spark plug help? ::: Solved
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RushT, Jun 5, 2022.
  1. Jun 5, 2022 at 5:12 PM
    RushT
    RushT [OP] Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Alrighty,
    I hit 60k and decided to go ahead and do my own plugs. Several YouTubes later, I felt confident. I went back to front, passenger side first. Fully completing each plug prior to moving on to the next. Disconnected the battery ground prior and reconnected after.
    Fired it up after all six and it sounded good… then it seemed to be missing a little. Drove down to the local gas station to fill up and definitely missing a little. I whipped up an OBD Fusion screen and it’s definitely logging misfires. Added another screen to look at all 6 cylinders. Cylinder 5 is the culprit.
    Pulled #5 out and checked the gap and all is good. Put it back in and similar result. Pulled it out and put an old plug back in. That *seemed* to resolve the issue. Pulled that one out and put the new one back in. Same misfire issue. I’m going to put an old one back in and test that theory again.
    Any advice at this point?
    <edit for solution and conclusion>
    Well, my replacement plug arrived in the mail a few days early. Pulled the old-old plug out and put in the new-new plug. No misfires at idle for 3 minute. I’m not going through the trouble of putting the old-new plug back in to test the conclusion that I got a bad plug in my original six.
    Thanks everyone for the contributions.
  2. Jun 5, 2022 at 5:14 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    What type of plugs? I've heard these are picky about oem/denso only...
  3. Jun 5, 2022 at 5:20 PM
    RushT
    North Texas
    OEM. I checked the gap on each prior to install. Guess I’ll swap two coils and see if the problem moves. Thankfully it’s #5, literally the easiest plug to change.
  4. Jun 5, 2022 at 5:25 PM
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    sub'd for the outcome.
  5. Jun 5, 2022 at 5:30 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    How about buying 1 additional new plug for #5 and see if that solves the misfire. Moving the coils may not help if it was running fine on 6 old plugs.
  6. Jun 5, 2022 at 5:37 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If replacing with old plug gave same result, then gotta suspect the coil. Unless you dropped something in the hole. Swap the coul as you suggested.
    Also check the coil plug connection. Inside the boot will be a spring. Check that the parts are not bent or broken, or missing.
    RushT[OP] likes this.
  7. Jun 5, 2022 at 5:46 PM
    Starman2112
    Starman2112 Well-Known Member
    2018 SR5 AC 4X4 Blazing Blue Pearl
    Where did you get the plugs? Amazon and eBay are riddled with counterfeits.
    Did you torque them to spec with no anti-seize?
    Skydvrr and RushT[OP] like this.
  8. Jun 5, 2022 at 6:01 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    yup.
    If they seem too good to be true...
    shakerhood likes this.
  9. Jun 5, 2022 at 6:17 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What did plug 5 look like?
  10. Jun 5, 2022 at 6:30 PM
    RushT
    North Texas
    Alrighty everyone…. Thanks for the advice so far.
    Anti-seize: guilty.
    Plugs from Autozone.
    Torqued to spec.
    Swapped coil packs and the problem didn’t go away. 4 mile drive and several stop/idle.
    Swapped plug back out and again it seems to clear up the issue. 3 mile drive and several stop/idle.
    Plug #5 didn’t look any different than the others. In general, not bad but they definitely have 60k on them.
    I’ll take it to work tomorrow with a cold engine and see how it does. If it does well, then hey, perhaps it’s a bad plug.
    wilcam47 likes this.
  11. Jun 5, 2022 at 6:38 PM
    RushT
    North Texas
    It’s a little frustrating. The total job wasn’t that hard. Passenger’s side maybe 30 minutes. Driver’s side a solid 45-60 minutes. Debugging??? 1hr so far.
    My low profile jack arrived today, so next week the weekender goes up on the stands for its plug change. Gotta take the back tires off for that one. Lol.
  12. Jun 5, 2022 at 6:40 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Get a new plug.
  13. Jun 5, 2022 at 6:40 PM
    3r3Taco
    3r3Taco Well-Known Member
    So.Cal
    17 SR5 DCSB
    Factory Stock
  14. Jun 5, 2022 at 6:46 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    My original suggestion would have been to swap the #5 coil to a different cylinder and swap new #5 plug to an other different cylinder, that way in one operation you can see if it follows the plug or the coil.
    That said at this point with all the plug swapping youve done I would just go buy one new plug and replace the #5 new plug, most likely that will fix it.
    wilcam47 and RushT[OP] like this.
  15. Jun 5, 2022 at 6:46 PM
    RushT
    North Texas
    Old on the right, new culprit (a few miles) on the left
    E80B7FEE-99D8-4E9A-B8A9-ADC7143DF409.jpg 3E1486EC-8EA4-40BE-BECC-CF84458F1003.jpg
  16. Jun 5, 2022 at 6:50 PM
    RushT
    North Texas
    Yep, that would have done it in one go. At this point, I could put the culprit in cylinder 3 and see if it goes there. But the $10 solution is an extra plug at this point. I wonder if Autozone will warranty it for me. :)
  17. Jun 5, 2022 at 6:51 PM
    TA2016
    Oregon
    RustyGreen and eurowner like this.
  18. Jun 5, 2022 at 6:53 PM
    RushT
    North Texas
  19. Jun 5, 2022 at 7:03 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Bad plugs happen, new just means new, doesn't mean good. I'd get a new plug
  20. Jun 5, 2022 at 7:09 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Have you changed the coil yet? Definitely a fan of doing that to see if the problem follows then replace with new whichever the problem persists (plug if still 5, coil if problem moves to whichever new spot)
    Best of luck
