Spark Plug help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandonlamb25, Nov 16, 2010.
  1. Nov 16, 2010 at 11:39 PM
    brandonlamb25
    brandonlamb25 [OP] Well-Known Member
    Georgia
    08 Crewcab Prerunner V6
    K&N Intake, Wet Okole Seat Covers, Ipod to Factory radio hookup kit, Black Low Pro Toolbox, Toytec Coilovers and 285/75r16 BFG MT's
    Ok, so I pulled my spark plugs (Denso iridium) today to look at them. They've been in for about 20-30k miles now. Im at 50k miles. Been hearing a lot about these E3 spark plugs. Anyways, when I removed my plugs I noticed that the porcelain looked really white and clean. I looked it up and found out the my engine is running lean. I haven't had any check engine lights nor error codes set off. Is it really too lean?? I have a K&N intake and most likely need to clean my MAF sensor (never done it). What do I clean it with?? I also have DTLT headers. Would I benefit from a URD MAF:
    http://www.urdusa.com/product_info.php?cPath=66_72&products_id=1260198051
    or maybe the URD MAF Fuel/timing calibrator:
    The reason I mention the second is because one of the fixes for a white (lean) plug tip is retarding the timing. Thanks for looking and helping.
  2. Nov 16, 2010 at 11:57 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    I don't know much about your particular problem, but I have heard that iridium plugs don't run great in 2nd gen 6 cylinders. I think Chris 4x4 did a write up on this in the technical chat forum.
  3. Nov 17, 2010 at 2:28 AM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
  4. Nov 17, 2010 at 7:20 AM
    brandonlamb25
    Georgia
    Have you used the plugs?? Is that just personal opinion or do you have more info on them to share?? Thanks.
  5. Nov 17, 2010 at 7:23 AM
    brandonlamb25
    Georgia
    I hope not. I can check where the headers bolt on. That would be the only place where there could be a leak at right?? I forgot to mention that I have a unichip and boreal exhaust and o2 sims for the back to sensors.
  6. Nov 17, 2010 at 7:40 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Nothing is better than the factory plugs.
  7. Nov 18, 2010 at 12:55 AM
    Leadgolem
    Greg
    Littleton, CO
    I was thinking that somebody may have tried to reuse the seals when the headers were installed. On a first gen, those seals aren't reusable. Don't know for sure if it's the same on a second gen.
  8. Nov 18, 2010 at 12:59 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    YUP.. factory is your friend on this particular engine.
  9. Nov 18, 2010 at 7:38 AM
    SCGuyInACOMA90
    SCGuyInACOMA90 Well-Known Member
    Alex
    Statesboro, GA
    2007 Silver Streak Mica SR5 4x4
    Leveling Kit, Westin Sportsman Grille Guard, 6000 K HIDs, PA/CB Radio, and much more to come!
    I have the Nippon Denso Iridium plugs in my truck and from what i can tell my truck still runs in an amazing fashion. those plugs are not designed to be ran for 50k from what i have heard since they are high performance plugs. hopefully its an easy fix but i really doubt u would have had any problems anyway... but it is better to be safe than sorry
