Spark plug help!
Discussion in 'Performance and Tuning' started by surfjones, Sep 25, 2009.
  1. Sep 25, 2009 at 11:29 AM
    surfjones
    surfjones [OP] Active Member
    Casey
    Houston
    05 DCLB Sport 4x4
    I ordered some Denso Iridiums from trdpart4u and they sent me IKH22's and I've read that most people replaced the stocks with IKH20's. Problem when I was at the shop the tech wasn't certain they were the right plugs bc the thread was longer then the stock ones so he wouldn't change them. So, even though they are longer can I still use these plugs? :confused:
  2. Sep 25, 2009 at 11:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    Send them back. They aren't for a Toyota
  3. Sep 25, 2009 at 11:48 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Sep 25, 2009 at 11:51 AM
    98tacoma27
    Ben
    Not Beech Creek
  5. Sep 25, 2009 at 11:57 AM
    surfjones
    Casey
    Houston
    05 DCLB Sport 4x4
    I spoke with Denso support and they said that they can be used for the Tacoma but would run colder for the TRD supercharger, but he was concerned that the thread was longer. He wanted to know what the original plug part number, which idk bc the plugs are already back in and I don't have the tools to take them out.
  6. Sep 25, 2009 at 11:59 AM
    surfjones
    Casey
    Houston
    05 DCLB Sport 4x4
  7. Sep 25, 2009 at 12:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yeah, I would stick with the 20's unless someone chimes in and says otherwise.
  8. Sep 25, 2009 at 12:12 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    I am running the IKH-22 plugs in my truck and have been for over a year.
    They will fit, and they will work. Though not recommended for N/A motors as they are a 2-step colder plug.
    The IKH20s are great for N/A
  9. Sep 25, 2009 at 12:28 PM
    surfjones
    Casey
    Houston
    05 DCLB Sport 4x4
    XrunnIT, were the threads longer then your original plugs?
  10. Sep 25, 2009 at 12:32 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    They were a plug and play swap.
    I pulled out the stock plugs, put the new ones in. Most of the boosted 1GR motors are running the IKH22's.
    I can't recall if the threads were longer. But I can tell you, that there are a ton of trucks running them, not just me.
