spark plug hole stripped
Discussion in '1st Gen. Tacomas (1995-2004)' started by Skingolo, Nov 6, 2022.
  1. Nov 6, 2022 at 4:06 PM
    Skingolo
    Skingolo [OP] Active Member
    2002 Tacoma 2wd
    Hello I have an 02 2wd with the 2.4. One of the spark plugs went out and I had a dead cylinder leaving work one day last week. I haul the truck home take out the coil packs and discover the 3rd cylinder spark plug is catching on the last thread. I eventually get it out but am unable to thread the new one in. Now I have the head off the block and am trying to insert a helicoil but have no idea how to tap safely with the spark plug tube as long as it is. Has anyone had this issue and found a solution? Do they make longer taps for this? I am really stuck and don't want to ruin a good motor more than has already happened.
  2. Nov 6, 2022 at 4:22 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You might be able to make or find an extension for your tap wrench
    Not knowing your skills I have brazed extensions on taps over the years .
    If things can not reach where needed .
  3. Nov 6, 2022 at 4:26 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would call a head shop and see if they have any way to repair it. They can repair cracks usually, I would think a stripped spark plug might be doable.
  4. Nov 6, 2022 at 4:30 PM
    Bivouac
    They could also Have a custom made tap just for these heads .
    making it a simple job.
    0xDEADBEEF[QUOTED] likes this.
  5. Nov 6, 2022 at 5:03 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Check out timesert... did the repair on a stripped lower unit drain hole on a outboard years ago and couldn't be happier on how it turned out. Didn't want to take the chance of dropping the tang into the lower unit with the heli coil. The timesert spark plug kit for your truck/motor will have everything you'll need including the correct reamer and tap.
    https://www.timesert.com/html/install.html
    Skingolo[OP] likes this.
  6. Nov 6, 2022 at 5:47 PM
    Skingolo
    2002 Tacoma 2wd
    I appreciate everyone's quick replies but I was actually able to fit the tap into the female end of a 3/8s extension. Very carefully tapped new threads and inserted a helicoil. Everything looks good and feels snug gonna need a head gasket but she's ready for reassembly.
    Bivouac, dbittle and Area51Runner like this.
